HDD GURU FORUMS
Data recovery and HDD repair discussions
It is currently September 2nd, 2010, 13:30
Forum rules
You may only create a new topic if you have more than 100 hard drives for sale. For other offers please use this forum: Buy&Sell parts, hard drives, etc
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Donor Drives for Sale
PostPosted: June 8th, 2009, 17:52
I want to correct my previus post
not the PCB but the entire HDD
WD5000KS
WD Caviar SE 16
model: WD5000KS-00MNB0
date: 15 NOV 2006
DCM: HCACAJAAB
PCB number: 2060-701383-001 REV A
white label: 2061-701383-E00 AH
I will need deliver to CERRO MAGGIORE MILAN ITALY
Please if some one has this email me at marcellino65@tiscali.it with the price and payment method.
Thanks.
PostPosted: June 9th, 2009, 10:36
hi would you have this hard drive:-
Model: - WD40000AAJs-00TKA0
DMC: - EBRCNV2ABB
Made: - Thailand
Date :- 05 April 2007
thank you
PostPosted: August 19th, 2009, 22:33
Hi All,
I accidentally plugged in the power cable of another external casing into mine and seems like the 12v came though the ground and my drive is completely dead now!! :(
I'm hoping a logic board replacement would fix it and hope it hasn't done any permanent damage to my data.
I'm looking for a logic board of this model:
Model: WD800JD-55MUA1
DMS: HSBANTJCA
Date: 20-OCT-2005
Logic Board nos: 2061-701335-A00 AH XW 2Q31 L1T5 7 0003160 6163
PostPosted: October 11th, 2009, 10:13
Good Day
Do u have WD800VE-00KWT0 it's IDE 2.5 Drive if u have plz let me know Thanks.
PostPosted: October 29th, 2009, 0:25
harddrivespecialist,
I need a pcb for the following:
WD5000YS-01MPB0
PCB: 2061-701383-e00 AE
DCM: HCACAJAA
A schematic would suffice if you don't have a board available.
Thank you.
PostPosted: November 19th, 2009, 0:44
I need this hard drive or the board. WD800BB-75BSA0, Malaysia, made June 10th 2001. Control board, 2060-001062-004
PostPosted: December 2nd, 2009, 13:58
I didn't see the PCB i need on your spreadsheet... just curious if you had one
I need one for a WD400JD-22LSA0 (2061-701335-A00 AH)
PostPosted: December 2nd, 2009, 15:06
I do have it.
Check your pm.
Don't gamble with your data!
PostPosted: February 7th, 2010, 9:23
I need the PCB for a
Barracuda 7200.8
Model:ST3250623A
P/N:9Y7263-560
Firmware: 3.04
Date code:06267
Site code:WU
Product of China
Can you help?
jazzcat_ro[at]yahoo.com
Thanks.
PostPosted: February 17th, 2010, 10:10
I need a PCB to replace my board of a barracuda 7200.8 250GB with the following description:
seagate barracuda 7200.8 250 GB
s/n: 5ND10GS0
Model: ST3250823A
p/n: 9Y7283-301
firmware: 3.06
date code: 06231
Site code: WU
chip1: ST E 100328754 B4387A2 96431015
chip2: smooth 100317176
I will need the board to be deliver to Italy.
Please if some one has this email me at iperdobler@yahoo.it with the price and payment method.
Thanks.
PostPosted: February 17th, 2010, 18:55
Can you upload a detailed photo of the component side?
What is the failure symptom?
PostPosted: February 18th, 2010, 9:25
The problem with my HD is that it can not be detected by the PC when turned
on, even if the disck are moving properly and there are not odd sound.
The HD is from a external USB box and it contains my backup, I opened the
box and tested the HD using two other IDEtoUSB adapters, but as I described
above, it is not detected by the PC.
So I thought that it could be a PCB problem, since, as I said, the disks are
moving properly and there are not strange mechanical sounds.
However, the PCB, from a visual examination, doesn't have any
damage/burn/defect, so the problem could be elsewhere...
I just want to add that the box has been tested with two different PC and in
many USB port.
PostPosted: February 18th, 2010, 17:42
The rule of thumb appears to be that, if a drive spins up but is not detected, or if it tries to spin up, then the board is probably OK. Instead the problem is most likely with the head/disc assembly (HDA).
If, OTOH, the drive makes no noise at all, and does not attempt to spin up, then the board is probably faulty.
When replacing the board, be prepared to transplant the 8-pin serial EEPROM chip from patient to donor. This is because the EEPROM stores drive specific calibration data determined at the factory.
The following article will help you identify the components:
http://hddscan.com/doc/HDD_from_inside.html
PostPosted: March 29th, 2010, 2:11
Online
This is a bad rule to follow. failure to power is just 1 symptom of a bad board. There are many many cases where power is good and PCB is not...
PostPosted: March 29th, 2010, 6:13
That's why I called it a rule of thumb.
http://en.wikipedia.org/wiki/Rule_of_thumb
"A rule of thumb is a principle with broad application that is not intended to be strictly accurate or reliable for every situation."
PostPosted: March 29th, 2010, 6:34
Online
Well at least there is no chance of you giving the wrong impression, or false hopes to an inexperienced newbie with no data recovery knowledge and a failed disk containing sentimental information....
PS - You must have links coming out of your a** , every post has one! Should change your name to Mr. Wikipedia i think :lol:
PostPosted: March 29th, 2010, 7:02
I don't consider my words to be Gospel. I'm not the fount of all knowledge. That's why I try to support my statements with references. It's good practice. Try it sometime.
PostPosted: March 29th, 2010, 7:14
Online
I would rather give my own information, this way I know it is valid and not simply pulled from a website somewhere written by someone I do not know. Try this sometime.
Sorry, this is assuming you have information of your own not leeched from one of your fabulous link archive :D
PostPosted: March 30th, 2010, 19:04
wow, hddguy, someone that speaks proper english on here :)
PostPosted: April 20th, 2010, 13:41
Do you have a PCB for the following drive?
WD400JD-55MSA1 HSBANTJCH
31 OCT 2005
2061-701335-A00 AH XC 2Q31 0EU5 8 0001160 6161
Malaysia
Mine was fried by a power surge from a bad power supply.
Users browsing this forum: No registered users and 0 guests
