Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
 Post subject: Identifying firmware chip
PostPosted: January 11th, 2017, 19:21
Can anyone be so kind as to tell me which is the firmware chip on this board (ST2000LM007)?
File comment: ST2000LM007 PCB
 Post subject: Re: Identifying firmware chip
PostPosted: January 11th, 2017, 22:14
between the TVS diode and the DDR memory chip
https://www.linkedin.com/in/artemrubtsov/
PostPosted: January 12th, 2017, 6:03
This little guy here?
Data Recovery Cape Town
PostPosted: January 12th, 2017, 11:23
that's the one
PostPosted: January 12th, 2017, 11:36
Thanks for that.
What is the world coming to...
PostPosted: January 18th, 2017, 16:26
And they are pigs to switch to a good PCB, if you're not a soldering wizard anyway!
Did one today, very fiddly!! :-)
www.pcimage.co.uk
PostPosted: January 19th, 2017, 16:17
Does the usual heatgun lift it and move it not work?
Maybe I'll fiddle with one tomorrow for giggles.
PostPosted: January 24th, 2017, 19:55
Thanks very much :) Had email notifications turned off for some reason and forgot I'd posted here so sorry for the late response as I've only just read your replies.
PostPosted: February 25th, 2017, 7:32
Wow ,
PCimage and Nick_CT This Is Just Like a Glass Crystal ,Got One for The First Time Today Man Everything is Locked In These HDD's .Coding Is 25S81 In My Rom
PostPosted: September 13th, 2017, 19:30
Now I was in doubt, is this the ROM chip or is it just a glass crystal :?:
PostPosted: September 14th, 2017, 1:58
It is the ROM chip, I have changed them before... It s not easy!
www.pcimage.co.uk
PostPosted: January 25th, 2018, 1:38
Has anyone succeeded in exchanging this pcb for hdd data recovery? It seems swapping this little crystal ROM isn't enough to unlock the board. Does main controller IC need be swapped as well? Coding in my Rom is 25S81 Thanks.
PostPosted: January 25th, 2018, 1:58
What do you mean?
PostPosted: January 25th, 2018, 11:23
With the original pcb, the hdd spins but can't be found by computer. After swapping the bios, the hdd even can't spin. It seems there is an bios in main controller too.
PostPosted: January 25th, 2018, 15:00
If the HDD spins OK with original PCB what makes you think the PCB is faulty?
www.pcimage.co.uk
PostPosted: January 25th, 2018, 15:08
Or you damage the ROM chip when transfering it to the new PCB ... Or solder it upside down, or did mess up with soldering, etc ....
PostPosted: January 25th, 2018, 15:42
That chance is low as I’m a chip designer and know how to handle this. Also the donor board can spin the hard drive with its own ROM but not the ROM from the original board. That make me think the MCU might have a portion of ROM as well. Both need be matched.
PostPosted: January 25th, 2018, 15:46
I found the Marvell hdd controller becomes very hot in original board. That makes me think the board has a damaged chip although the motor can still spin.
PostPosted: January 25th, 2018, 15:50
Are you sure the PCBs are compatible ? Do they have the same RAM size ?
PostPosted: January 25th, 2018, 15:55
Yes, same board, REV, FW, everything, even ROM footprint.
Users browsing this forum: we3fan and 42 guests
