Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
 Post subject: Re: ST500DM002 - media damage?
PostPosted: July 18th, 2017, 8:55
Patient is:
Model: ST500DM002-1BD142
SN: Z3TKNZEY
PCB SN: 0000C344C556
DATE: 05-05-2013
Donor is:
SN: Z3TC8SCM
PCB SN: 0000732365V1
DATE: 13-12-2012
try the attached rom, with donor heads in patient drive, it might help.
patch-rom.zip [214.59 KiB]
Downloaded 349 times
Data Recovery Pakistan
PostPosted: July 18th, 2017, 16:41
cheadledatarecovery wrote:
Just spotted the 'word-wrap' issue. No idea what has caused that!
J
A line with no spaces cannot be wrapped.
PostPosted: July 21st, 2017, 12:34
now the question is what's on the sticker...
please, could we sort this out within then next 10 posts? :)
PostPosted: July 22nd, 2017, 1:02
:mrgreen:
Seriously Pepe Sir :lol:
PostPosted: July 22nd, 2017, 1:39
Patient heads in donor drive have failed ==> likely degraded head.
The highlighted in red Servo response/recovery messages are likely due to the degraded head unable to perform the power up initialization at the system area. Since HSA-swapped having the same error message and it could be means that the system area has been damage/scratch due to the HDI "Head-Disk Interference" effect, could be a light scratches along the SA.
I'm not sure if your current tools able to measure the resistance of the MR heads? If yes, it's worth to try out to further confirmed the head degradation on the patient drive.
Donor – Match on all of above.
Similar symptoms as per: http://forum.acelaboratory.com/viewtopic.php?t=8273
Disk stays spinning. Terminal output below.
Work so far:
• Tested patient with donor PCB, no change.
• Attempted shorting read-channel with patient heads inside. Cannot get to T> . When shorting at the ‘correct’ time, drive spins down after a number of clicks, but will still will not provide T> .
• Opened HDD, inspected heads under microscope – no visible damage. In the HDA there are small signs of contamination, hard to see silver coloured fragments (Yes, not good I know!)
Use of donor heads in patient provide the same results. After swapping donor heads back into donor they still work OK.
Patient heads in donor drive do not work – they have failed.
If there was significant damage to the platter I would have expected the donor heads to have degraded, and not be functional once they were swapped back into the donor. However, the tiny amounts of silver coloured fragments would suggest some media damage, perhaps to SA? More likely than not media damage on this disks, but trying to exhaust all possibilities.
Any suggestions are welcome on this one.
Thanks,
John
Terminal output:
Boot 0x10M
Spin Up
RECOV Servo Op=0100 Resp=0005[0x00000000]
RECOV Servo Op=0055 Resp=0005[0x00000000]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMddddddWWWWMMMMMM
FAIL Servo Op=0155 Resp=0007
ResponseFrame 0000 0000 0000 0000 0020 0000 0000 0000 0F98 0000 0000 0000 0000 0000 0000 0000 000Ax
RECOV Servo Op=0155 Resp=0005[0x00025CB4][0x00025CB4]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMddddddWWWWMMMMMM
FAIL Servo Op=0055 Resp=0007
RECOV Servo Op=0155 Resp=0005x
RECOV Servo Op=0055 Resp=0005[0x0000B319]
RECOV Servo Op=0055 Resp=0005[0x0000B319]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMddddddWWWWMMMMMM
RECOV Servo Op=0055 Resp=0005x
RECOV Servo Op=0155 Resp=0005[0x00030FCD][0x00030FCD]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMddddddWWWWMMMMMM
PostPosted: July 22nd, 2017, 5:03
This disks has differents preamp .
Donor PREAMP_ID : 0459
Patient PREAMP_ID : 0373.
Try use other donor.
PostPosted: July 22nd, 2017, 5:29
good point, that can be a problem too. So transfering adaptives might help as well.
PostPosted: July 22nd, 2017, 13:17
Well,
So many drives will many different heads this could be but is not mandatory
PostPosted: July 23rd, 2017, 4:53
i send you a PM, please respond to it.
thanks
Users browsing this forum: Google Adsense [Bot] and 172 guests
