 Post subject: While matching Donor pcb ,is rev. also to be matched
PostPosted: July 7th, 2019, 7:38
I want to know whether Rev. is also must be matched for compatibility of donor pcb ?
for example ---
Patient PCB --- 100535704 - Rev. D
Donor pcb------100535704 - Rev A /B /C
Will they match or I will be needed to be more specific for Rev D only.
 Post subject: Re: While matching Donor pcb ,is rev. also to be matched
PostPosted: July 7th, 2019, 10:57
Yes, sometimes. But in your case it shouldn't matter for that model Seagate.
PostPosted: July 8th, 2019, 1:19
Thanks samick :good: :-D
PostPosted: July 12th, 2019, 1:45
Thanks samick , pcb matched. Can you pls.throw light as of rev.does not matter with all other seagate models and for Toshiba as well ?
