 Post subject: ST3750528AS
PostPosted: February 13th, 2020, 13:36
Hi all,
Got a few of these of ebay as faulty drives and hooked them up to terminal to see what was happening and they seem to be fine. I get the
Rst 0x20M
Servo Processor Is Reset.
RW: Disc Ctlr Initialization Completed.
ExecuteSpinRequest
(P) SATA Reset
But when I try to enter terminal through the ctrl + Z command, nothing happens. Its like terminal is locked or frozen. I saw a post about shorting the read channels, but is that what I need to do to get terminal to work.
I'm planning on selling the PCB boards anyway, so they look to be working, drives spin up and read, but looks like a ton of bad sectors in important areas of the disk to stop formatting, creating partitions and so on.
Many thanks
Shane
 Post subject: Re: ST3750528AS
PostPosted: February 14th, 2020, 18:22
Here are some images of the PCB. Which channels do I short to get terminal responding. Not sure if the read channels should be shorted to ground.
PostPosted: February 14th, 2020, 18:53
I'm looking at the forums, wondering if this might need 1.8V to work, or its a low voltage board. Not sure if it is. I get the terminal information, but cannot Ctrl+Z into terminal. Its only locked on (P) SATA Reset. Any ideas?
My USB Serial adapter uses 3.3v I think.
PostPosted: February 14th, 2020, 19:38
Tip: How to identify the Read Channel test points:
http://www.hddoracle.com/viewtopic.php?f=24&t=123
PostPosted: February 20th, 2020, 9:42
Thanks for that. I haven't done anything with the drive, it more like a hobby fix if I can, but one question still remains, is this terminal voltage on this PCB 1.8V OR 3.3V
I think it's 3.3V because I am able to see the drives output terminal results, but I cannot enter the terminal mode or send commands.
Also, do these drive run a self scan when sitting Idle. Hopefully that might map bad sectors in the system area if I leave it running.
Thanks for help
Shane
Users browsing this forum: MSN [Bot] and 42 guests
