pepe wrote:
i meant to connect the adapter's TX to its RX, without hdd . Just to test if your adapter is working. you should see the characters you type appearing in your terminal window (without local echo enabled!)
Honestly, this thread went beyond all imagination. What the crap we are doing here if you can't connect 3 wires?
You should admit it does not work for you and decide what to do with the drive, bin it or ask pro help.
hey
idk why you so upset , if i already explained and said , no output whats so ever on the hdd.
the adapter works , i have connected it to a different board (not related to hdd) to read out UART from it. and it worked .
and if i connect the tx to rx on the adapter itself i do see art effect
