 Post subject: Seagate ST3160812AS Data recovery
PostPosted: April 6th, 2024, 17:20
Hello. I have a few questions. I would be happy if you help.
I have a model hard disk.
ST3160812AS - 9BD132-302
3rd AAD
Donor hard disk
9BD132-021
3.AHL
I transferred the disk of my faulty hard disk to the donor hard disk without any problems. (The disc is spinning and there are no scratches, no clicking noise).
I transferred the ROM successfully.
When I read it with Hyperterminal, it returns a result like the following. (image_1)
I can't get to F3 > level on the command line. It always stays at F. (no 3)
Where should I start? What can I do?
The files don't matter much. I'm just trying to learn.
File comment: image_1
 Post subject: Re: Seagate ST3160812AS Data recovery
PostPosted: April 6th, 2024, 18:53
-that disk is not F3 arch, that's why you don't get F3 prompt.
-why did you transfer the ROM?
-why did you transplant platter instead of head assembly?
It cannot read boot adaptives from the SA, which can be due to wrong pcb, wrong fw, weak heads.
if you wanna learn, reassemble the donor and check if it still works :)
PostPosted: April 7th, 2024, 16:29
Hello Pepe. Thank you for your answer.
As you said, I restored the Donor hard disk to its original state. I restored the ROM I backed up. Now the terminal returns the result as follows. The disk is no longer spinning.
What should I do now.
PostPosted: April 7th, 2024, 16:38
Note:
. The command returns a result like the following.
Pgm=00 Trk=00000000(00000000).0(0).000(000) Zn=2E Err=29 ErCt=0000 Hlth=0000 C
Hlth=0000 Ntrdy LBA=00000000
PostPosted: April 12th, 2024, 4:30
Something is wrong with ROM. You need to check if you solder it back right
PostPosted: April 26th, 2024, 17:55
I found a new donor hard drive.
Everything is exactly the same. Model, Firmware, site code all numbers match. Production dates differ by only 3 months.
Now, if I transfer the disk I have to the donor's hard disk, will I still need to transfer the old BIOS integrated? (Firmware same 3.AAD).
Also, is it necessary to align the plate? (There is only 1 plate)
PostPosted: April 28th, 2024, 3:31
if firmware is the same you don't need to move rom. Most likely you don't need to align plate.
