Post new topic Reply to topic  [ 94 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: ATA password bypassing
PostPosted: May 16th, 2009, 9:43
Hello everyone
What is the latest status with 'bypassing' ATA passwords ?
I was following progress in this area approx 3 years ago
especially as XBOX(v1) 5GB harddrives were locked via the ATA password
and there were many debates about any way to unlock if you didnt have the xbox main board eeprom with the password etc
At the time no one had found a way to bypass it, even trying live swapping of hdd electronic boards
The ATA password is probably on the reserved (manufactuerer system) area of the disk
rather than on eeprom on the electronics
so if you could fool the electronics into thinking it had unlocked it (from a known platter) mighht be able to switch to a target (locked) platter and read off the user sectors
etc
Or some way to zap or shortciruit the logic on the controller board to force unlocking
So, any developments in this area
 Post subject: Re: ATA password bypassing
PostPosted: May 16th, 2009, 9:54
So, you came into the HDDGURU forum for what reason ? :mrgreen:
PostPosted: May 16th, 2009, 10:11
It's easy to unlock when you know the vendor commands or the terminal commands ! :D :D :D
If you need to unlock a specific drive PM me.
It is completely doable and no, it doesn't involve the PCB in any way.
PostPosted: May 16th, 2009, 10:32
It's like HEART bypass... some people are good at doing it, some other not :mrgreen:
PostPosted: May 16th, 2009, 11:09
:cry: :cry: :cry:
If it's a WD drive i can bypass it. All of them.
I can do the same to all Seagates.
PostPosted: May 16th, 2009, 11:27
Me too. And on Fujitsu, Samsung, Excelstor, Hitachi and so on... :mrgreen:
PostPosted: May 16th, 2009, 11:37
I can unlock on Fujitsu, some Samsungs and Maxtors.
The only ones i can't do is Hitachi/IBM.
PostPosted: May 16th, 2009, 11:38
And by the way, a little off-topic but i've found a very coooollllll thing ;)
PostPosted: May 16th, 2009, 11:54
Getting back to the topic, there have been multiple posts about it here. I'm sure if OP was really interested he could turn something up.
PostPosted: May 16th, 2009, 12:11
Those 5GB drives are very old and well documented ....
Try Master passwords, if no joy, post the model of the drive.
PostPosted: May 16th, 2009, 13:48
Thanks for the tips
No particular reason, other than I've been watching some of the myharddrivedied videos on youtube
(and I used to do that sort of thing a few years back)
and he mentioned the mhdd program
and it reminded me of this topic
and I wondered if there had been any progress on it.
Sounds like there has, but your all being a bit secretive about it :-)
although of course the techniques must be very specific to specific drives and firmware revisions
PostPosted: May 16th, 2009, 13:53
Hitachi are hard the others are easy, even without expensive tools.
PostPosted: May 16th, 2009, 14:01
The PC3000 sofware (and interface card) looks very interesting...
Does it need the dedicated IF board or will it run or partially run with a standard ide/ata controller ?
PostPosted: May 16th, 2009, 14:27
@Spildit,
I need to ask your opinion about something that bothers me.
At the company I am working, we have a lot of mini drives (My Passport Essential).
When our people securely disconect the drive, the led remains on and can not figure out if the drive still works or not, because by its nature it does not make any noise.
How can i confirm that the heads are parked securely?
Are there any windows utilities (hdparm -Y) that can help?
Any comments, propositions?
Eleana
PostPosted: May 16th, 2009, 14:47
No, pc3000 is card +sw.
PostPosted: May 18th, 2009, 7:32
Hello, me again
Will these techiniques also work in the Maximum security mode where it needs the User password and ignores the Master password.
Or in the lower 'high security' mode if the Master password had been changed
Or can we do a SECURITY ERASE PREPARE immediately followed by SECURITY ERASE UNIT but physically cut the write signal to the heads
-- but then it cant upda the SA, but might leave the firmware thinking its unlocked ?
Supplemental Q
Will mhdd or something similiar let me see the raw hex of the IDENTIFY response
or fully decide the words and bits
(else I'll have to breakin and see the raw data)
Thanks again
PS Of course I mean getting to the data rather than just reusing the drive
PostPosted: May 18th, 2009, 13:02
win.7 wrote:
@Spildit,
Eleana
I will reply to your PM later today.
PostPosted: May 18th, 2009, 13:03
The techniques allow you to access the Master and User password saved on the drive, so you can use that same password to unlock the drive.
Mhdd with scripts can do lots of usefull stuff.
xsoliman wrote:
Hello, me again
Supplemental Q
Thanks again
Users browsing this forum: No registered users and 31 guests
