 Post subject: Seagate 7200.11 ST3320613as wont initialize showing 0-size
PostPosted: January 29th, 2010, 13:24
Firmware CC2f
any one else had a problem with these ?.... is it a firmware issue or hardware ?
 Post subject: Re: Seagate 7200.11 ST3320613as wont initialize showing 0-size
PostPosted: January 29th, 2010, 13:31
This drive has Seagate's new super compression and can compress 320GB of data down to 0MB.
I can't say that I've encountered this particular firmware, but would be suspicious of it being victim to the common issues of the 7200.11 series. Does the drive make any unusual sounds when powered on? Do you have the ability to read the terminal output?
I suggest getting it assessed by a professional lab with all the necessary tools. If the data isn't worth it, get it replaced under warranty.
Recovery Force Data Recovery
PostPosted: January 29th, 2010, 13:39
no the drive sounds good, spins up ok, is detected by windows and bios but just wont initialise >.<
got to love seagate !!!.... is it worth trying the reset as per the busystate firmware ?...
3rd time off tring to initialise came up with : " The request could no be performed because of an I/O device error "
PostPosted: January 29th, 2010, 13:56
Restored.... i used terminal comands.. U= spin up ok, F,,22= drive config restored,,, N1= smart reset, M0,2,2,0,0,0,0,22 user part max rd etc, etc.. unpluged, conected back to pc and drive is on and i have acsess to the files !!!! :)
PostPosted: January 29th, 2010, 14:15
Does any one know of a firmware update for this drive ????.... its working at the moment but kind of feel like i have a time bomb here :(
PostPosted: January 29th, 2010, 14:29
Copy data off it and RMA it!
Data Recovery Ireland
PostPosted: January 29th, 2010, 14:37
ok... but will they not question why its working now ?....
PostPosted: January 29th, 2010, 16:38
They may or may not...
PostPosted: January 29th, 2010, 19:58
Don't be tempted to flash a CCxx drive with SDxx firmware. Seagate warns that doing this will render your drive inoperable.
If you can get your drive to fail SeaTools, then Seagate will accept the failing Test Code as your evidence, even if the drive subsequently comes good.
About SeaTools Test Codes:
http://seagate.com/ww/v/index.jsp?local ... 48090aRCRD
"SeaTools Test Codes are based on the type of test that failed and the product serial number. No two codes are the same. The online RMA submission system will use the SeaTools Test Code number to help process the exchange of your product. The code tells Seagate that the drive is, in fact, bad and that there is virtually no chance that a good drive is being returned."
PostPosted: March 20th, 2024, 3:43
Same Issue with me , DRD DSC
But any command given to terminal give LED error
Tried Reading Sys Files through ATA/Serial , Gives LED error as well
PostPosted: March 20th, 2024, 8:47
Wow, a .11 BSY bug! Haven't seen one for years! Those were the days!
As far as I remember, the DIY approach was:
- Isolate PCB from HDD with a business card
- Power on the drive
- F3 T>/2Z
- Remove the card and screw the screws
- F3 2> U
- F3 2> /Tm0,6,2,,,,,22
In some rare occassions SMART reset was needed (/1N1) and some people said clear g-list also needed but I don't find it a good idea without proper checks.
DON'T TRY THIS ON ANYTHING OTHER THAN .11!! Trying it on a .12 will give you partial access problem and the translator will have to be re-created with nrg list into account!
PostPosted: March 20th, 2024, 11:10
In fact, that command can give partial access on .11 as well (like my very first .11 case).
PostPosted: March 20th, 2024, 11:31
And after F3 2>U read system files or modules?
Before F3 T>Tm0.....
PostPosted: March 20th, 2024, 15:29
If i remember well, on some of this 7200.11 it is needed to insulate motor instead HDA.
On some others, it is needed to completely remove pcb from hdd.
My firmware database:
https://mega.nz/folder/O01DkBRI#MxP2J6ZNqXDcrX40I8MoQQ
PostPosted: March 21st, 2024, 15:05
never seen this, but it shouldn't be a problem anyway..
PostPosted: March 21st, 2024, 21:24
well, i had no other Moose case having entries in NRG either, only the very first one, it was even before commercial solutions appeared...
So it seems i was 'lucky' enough :)
well in a way i was lucky, coz in a few hours i knew the cause of the so called 'partial access problem' and was able to handle it, most ppl knew nothing about it for years.
Users browsing this forum: No registered users and 128 guests
