 Post subject: WD30EZRX really slow
PostPosted: October 8th, 2017, 22:39
I have a WD30EZRX 3.0TB drive that is suddenly *really* slow, and after digging around it seems like the problem might be somewhat well known, the only problem is all the posts I could find about it are as old as the drive, the data on the drive is not unreplacable, and the drive itself works, just hoping there is a way to get the data off without it taking a month.
 Post subject: Re: WD30EZRX really slow
PostPosted: October 9th, 2017, 14:35
Here :
http://www.hddoracle.com/viewtopic.php? ... t=60#p9874
http://www.hddoracle.com/viewtopic.php?f=86&t=848
http://www.hddoracle.com/viewtopic.php?f=59&t=1456
PostPosted: October 9th, 2017, 20:09
Thanks... was hoping there was some kind of newer firmware tool, other than WD marvel thing.. I have a copy of WDR, but naturally I am on 64-bit windows.. and it doesn't work on 64-bit OS, so its either put together something that can run 32-bit, pay for WD-marvel, or just consider most of the data a write-off (which is honestly the most likely option at this point)
PostPosted: October 10th, 2017, 16:20
There is also the free HDDSuperTool ....
PostPosted: October 10th, 2017, 18:47
Banned User
most of hdd repair tools only work in 32 bit windows :D :D :D
Mohammad Mazaheri
Email: mazaheri.online@gmail.com
Mobile: +989185005214
PostPosted: October 10th, 2017, 22:26
Yeah, thanks everybody for the help, was hoping there was some easier way to recover the data, its not worth the trouble of getting a 32-bit or Linux box going (anything actually important was backed up in at least one other location)
PostPosted: October 12th, 2017, 18:11
Ok ....
If you can't go to the trouble of setting a machine to run those tools then the data is not important at all.
Glad that you did had backups !!!
:D
PostPosted: October 12th, 2017, 18:50
If the Linux box reference is to being able to use HDDSuperTool, a live CD is available.
http://www.sdcomputingservice.com/hddlivecd
It can also be made into a live USB with some popular tools that can create a bootable USB from a CD.
Home of HDDSuperClone and HDDSuperTool
Users browsing this forum: Bing [Bot], Google [Bot] and 10 guests
