 Post subject: st3100340as not initializing in windows, spin error.
PostPosted: July 21st, 2010, 0:27
I had fixed this hard drive already a couple of months ago because it had the bsy error, not being recognized in bios. fix i usedhttp://forum.hddguru.com/seagate-7200-bsy-error-12cc4-message-t11869.html
It was working fine [powers on, no abnormal clicking sounds] and then this week, it started getting slower to access the drive, windows would take about 10 seconds to show the contents of the drive.
It got worse to the point where windows couldn't even see the drive anymore, tried using disk management and it could not initialize the drive [ drive busy error].
I took out the cables I used before to do the fix and got back into the drive to try and do the fix again.
This time when I took out the paper after spinning down properly and tried to spin the drive up, I keep getting this error:
F3 2>U
DiagError 00006008
Spin Error
Elapsed Time 24.021 secs
R/W Status 2 R/W Error 84150180
Any help would be appreciated.
Thanks.
 Post subject: Re: st3100340as not initializing in windows, spin error.
PostPosted: July 21st, 2010, 1:44
Replace drive OR ask for pro help. For example we can make it re-utilizable again at a reasonable price taking into account that in any case it is low quality cheap drive. Any qualified pro should have the gear and k-h to fix the drive.
PostPosted: July 21st, 2010, 21:12
Hey,
Sounds like its an easy fix, is there any way I could do the fix without special tools you that hd specialists use?
If not, can you recommend anyone in the Toronto[canada] region?
Thanks.
PostPosted: July 22nd, 2010, 2:11
NOT EASY FIX. It is possible at low price to FIX THE DRIVE BUT LOOSING DATA ON IT - EVERYTHING. Otherwise, it is data recovery at data recovery price too.
PostPosted: July 22nd, 2010, 2:45
fickit1time wrote:
Hey,
Thanks.
lol your diagnosis is not even close.
Zero Alpha: zeroalpha.com.au
Find Cheap Donor Drives App: https://www.zeroalpha.com.au/donor-drive-app Updated February 2026
PostPosted: July 22nd, 2010, 5:27
fickit1time wrote:
F3 2>U
DiagError 00006008
Spin Error
This is why professionals are called professionals, and newbies are called newbies. It is to differentiate those who have a clue from those who dont.
PostPosted: July 22nd, 2010, 12:05
Um.. lets not make this a thread about newbies vs professionals please.
If you have some further comments to make please keep it to the diagnoses or treatment of the failed drive.
Thanks.
PostPosted: July 22nd, 2010, 12:09
This is unavoidable when there is clearly a lack of ability in dealing with this issue, and instead lots of assumptions about how easy the repair could be.
If you want my opinion, you should have learned from your initial failure and made backups, now you are left with a hard disk that only a professional DR firm can deal with.
PostPosted: July 22nd, 2010, 12:14
Thanks.
Diagnosis - The HDD is not functional.
Solution - Send it to a pro near you.
PostPosted: July 22nd, 2010, 12:24
in soviet russia, pro come to you
PostPosted: July 22nd, 2010, 12:36
Haha.. if only north america would follow some of what you russians do.
Any DR in the Toronto region?
The drive contains only media stuff, I don't want to spend more time downloading again.
PostPosted: July 22nd, 2010, 12:39
I think you will download that stuff again :D
Users browsing this forum: No registered users and 21 guests
