Iurii wrote:
First of all 1 KB stripe size is rare. More often its 512 bytes or 4KB. So most of all your configuration is wrong. That is confirmed by results.
You may easily check is your configuration correct or not - make RAW scan and check files bigger than 1KB. Usually it take 15-20 minutes to find configuration of RAID0.
One more question: how much damages clusters (bad sectors) and where they are located on drive?
PM please if need assistance
Thankyou very much for helping, Problem was solved in 18 minutes thankyou again Iurii
