einstein9 wrote:
shahij wrote:
same here...
Patient was spinning fine but with the donor after swapping U12 doesn't even spin.
Patient PCB: 2060-701675-001
Donor PCB: 2060771672-004
Not every advice is actually an Advice, and not everything you read is actually true,
some helps n some kills.
and for sure this is one of them.
it is like while you are reading a book and skipping the 1st. few chapters and jumping to the END of the book
looking for the Conclusion.
good luck
YES
"TRUE"yes, what is in your mind if things are followed !!! yeah, everything was done right as required... To clarify...
I require to access SA (converting into SATA was essential), tried the donor board as mentioned for converting into SATA, but unsuccessful due to IT STOPS SPINNING with DONOR Board, but things are taken back to USB and SPINS file like before.
Is it happening for PCB incompatibility or something else? (MCU are same into the both PCB)
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
