Post new topic Reply to topic  [ 31 posts ]  Go to page 1, 2  Next
 Post subject: Toshiba (lenovo) MK5061GSY ATA password unlock
PostPosted: March 18th, 2014, 15:10
I've got this hdd from an lenovo laptop and it has an ata password on it, is there any free solution for this to unlock?
Can somebody please help me??
 Post subject: Re: Toshiba (lenovo) MK5061GSY ATA password unlock
PostPosted: March 18th, 2014, 16:17
"ZU" may well do the job for you.
PostPosted: March 18th, 2014, 18:16
I tried that before the latest one but no luck
PostPosted: March 18th, 2014, 23:36
Lenovo FW has additional protection, I don't think free tools would serve much help
https://www.linkedin.com/in/artemrubtsov/
PostPosted: March 19th, 2014, 16:53
yeah i thought so, but i thouhgt also you never know :) maybe someone send me a pm with an solution :D
I heard even from MOLTKE that you also not connect it through terminal, probably protected.
PostPosted: June 5th, 2019, 14:22
Soo after 5 years later i'm back with the same HDD. :)
Still no free solution??? :)
PostPosted: June 5th, 2019, 14:45
I think that i can unlock it for you.
https://www.ebay.com/itm/ATA-Password-U ... 2861542747
If i can't unlock it i will refund your $$$ but most likely it's easy to unlock even if it's from a Lenovo ...
PostPosted: June 7th, 2019, 16:50
thank you Spildit,
but i was looking for a DIY, i dont want to spent any money for this hdd because its not worth it.
If there are still no free solution for this then i put it in the closet and come back again years later
PostPosted: June 7th, 2019, 17:28
You might need to get "normal" main ROM code and move all CPs from your ROM to the "unlocked" ROM if special "Lenovo" ROM main code is preventing the use of VSCs. Then you need to send the VSC to regen the "S" sector on platter or as alternative read/write that sector by PBA...
No free sollution. Most likely there will never be a free sollution for this unless the VSC that is used to regen "S" somehow does work on your drive even with "Lenovo" firmware ....
PostPosted: June 10th, 2019, 13:07
ok,
is it possible if i read the rom with mine programmer to see the password encrypted somewhere in de dump?
PostPosted: June 10th, 2019, 14:07
NO.
The password is NOT on the ROM. It's stored on the "security" or "S" "sector" on the platters.
You need either to use a VSC (vendor specific command) to re-gen that "S" sector to a default one (unlocked) or you need to access that sector by PBA (using of course vendor specific commands) and replace that sector with one of an un-locked drive ...
PostPosted: June 11th, 2019, 4:09
:shock: :shock: :shock:
You say this?
It's a 1-minute job. SON + VSC...
PostPosted: June 11th, 2019, 7:47
You say this?
There are some drives that don't behave like that ... Meaning on some drives with "patched" or "special" main code terminal will be locked and S-ON will not work or if it does work all other VSCs are blocked ....
I did saw this mainly with DVR locked drives ... You can't even read ROM by terminal, access CPs by VSC, etc ...
You do need to read ROM with extrenal programmer, carve the CPs and write those to ROM with normal main code, then you can use VSC to re-create "S" or read/write "S" by VSC ...
PostPosted: June 12th, 2019, 3:24
In fact it's much easier....
:D :D :D
PostPosted: June 12th, 2019, 7:34
Yes, if you do know some sort of VSC or if you have a way to unlock terminal, etc ...
PostPosted: June 12th, 2019, 7:38
:D :D :D
At any rate this doesn't help the OP with anything ..
Maybe you should PM him the VSCs to unlock the drive ?
:mrgreen: :mrgreen: :mrgreen:
PostPosted: June 12th, 2019, 9:33
I could as well as you could, too. But I don't want to mess up with your business.
https://www.ebay.com/itm/ATA-Password-U ... 2861542747 "
PostPosted: June 12th, 2019, 12:23
You say this?
AFAIR (was 5 years ago) SON is locked on those
PostPosted: June 12th, 2019, 14:37
Doomer wrote:
You say this?
This is what i think as well, like on DVR Locked Toshiba, SUPER ON doesn't work so any other "super" command will be rejected.
PostPosted: June 12th, 2019, 14:53
I don't have any problem with that !!!
Just post the sollution here if you want to !!!
Users browsing this forum: Google [Bot] and 28 guests
