Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
 Post subject: Re: Toshiba (lenovo) MK5061GSY ATA password unlock
PostPosted: June 12th, 2019, 16:55
do i need some special software or hardware to unlock it?
i unlocked some disk with ZU and Seagate with Zoc script.
i have external programmer to read the rom( I think i already read the rom a few years ago)
Any secrets or tricks will be apreciated :D
PostPosted: June 12th, 2019, 17:13
You need special vendor specific commands if you don't want to pay for SeDiv or similar product .... Apart from that let's see if our friend @BGman can assist ...
I think he does know a way to gain access to SA/VSCs even if SUPER ON is blocked ....
:mrgreen: :mrgreen: :mrgreen:
He just have to post the commands and you just have to send them to the drive using any free ata terminal like for example HRT demo or even by TTL (ata over TTL, etc) ...
PostPosted: June 13th, 2019, 3:34
Doomer wrote:
AFAIR (was 5 years ago) SON is locked on those
I don't think so. I have repaired a lot of Lenovo drives - no one locked.
Anyway. When one door is closed, another one is left open...
PostPosted: June 13th, 2019, 3:57
Spildit wrote:
BGman wrote:
I could as well as you could, too. But I don't want to mess up with your business.
I don't have any problem with that !!!
Just post the sollution here if you want to !!!
This is not only yours business!!!
When somebody ask you to unlock his drive what do you do? Mail him VSC's or ask him to send you the drive?
PostPosted: June 13th, 2019, 14:04
Send a link to my eBay unlock service ?
PostPosted: June 13th, 2019, 14:05
This will be even easier then !
PostPosted: June 17th, 2019, 15:11
Ok,
i got some news, i have found the bios dump of the lenovo where this hdd is from.
The password from the laptop is on this dump (see picture) 2 same lines with encrypted password, i'm 99% sure this password is also the hdd password.
can i use this with victoria?
PostPosted: June 17th, 2019, 18:02
zenelli wrote:
Ok,
I don't think so.
ThinkPad BIOS Password Design for UEFI:
http://monitor.espec.ws/files/lewnovo_password_399.pdf
Password Characters and Data
• Supported characters
– Alphabet (case insensitive)
– Number
– Space ‘ ‘
• Code set
– Scan code
• Maximum length
– 64 characters
• Data transformation
– Hash 64 scan codes by SHA-256 and take first 16 bytes
Power On Password
• Storage
–Inside HDD
–Security feature is locked by SET FREEZELOCK command
• before exiting POST
• when the _GTF is evaluated by a storage driver at resuming from S3
• Salting
–Salted with the hashed Model number and the serial number before sending to HDDs
• Master HDP and User HDP are supported
Supervisor Password
• Requested to input when:
– BIOS Setup is invoked
– Signature diskette is detected
– EFI Shell is invoked
– BIOS update is invoked while OS is running
– TPM state change is invoked while OS is running
• Storage
– EEPROM Block 6 (C2 Space)
10-1Fh: Primary SVP
20-2Fh: Backup SVP
• Salting
– Salted with the random number in the boot block before storing in the EEPROM
Hard Drive Password
• Storage
– Inside HDD
– Security feature is locked by SET FREEZELOCK command
• Salting
– Salted with the hashed Model number and the serial number before sending to HDDs
PC Keyboard Scan Codes:
http://www.users.on.net/~fzabkar/MSKeyLog.TXT
PostPosted: June 17th, 2019, 18:19
Sorry, that should have been ...
Power On Password
• Requested to input at:
– Boot
– Waking up from Hibernate (POST)
• Storage
– CMOS
Lower 38-3Fh: First 8bytes of hashed passphrase (Offset 0-7h)
Upper 38-3Bh: Remaining 4bytes of hashed passphrase (Offset 8-Bh)
Upper 3Ch : Checksum of lower 38-3Fh and upper 38-3Bh
– Storage are locked
• before exiting POST if the signature diskette is not detected
• before jumping to OS waking vector
• Salting
– Salted with the random number in the boot block before storing in the CMOS
PostPosted: June 17th, 2019, 18:29
Lot easier to just use the VSC to regen "S" ...
PostPosted: June 17th, 2019, 18:41
If you have the original laptop, does this mean that the [unhashed] HDD password is known and that you are needing to circumvent the password because the laptop is dead? If so, have you tried the HDD in another Lenovo laptop?
PostPosted: June 22nd, 2019, 17:59
No i dont have this laptop anymore, and no i dont know the password. i bought this laptop long time ago with bios and hdd password, the bios password i could read it with special software and removed it (See picture of dump)
the hdd password is the same i think with the bios password
PostPosted: June 23rd, 2019, 2:44
After hashing, the results would be different.
"Salted with the random number in the boot block before storing in the CMOS"
"Salted with the random number in the boot block before storing in the EEPROM"
"Salted with the hashed Model number and the serial number before sending to HDDs"
Users browsing this forum: Google [Bot] and 52 guests
