Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
 Post subject: Re: Convert USB Toshiba MQ01UBD100 to SATA
PostPosted: December 31st, 2016, 2:07
I am trying to get the corresponding ROM chip, but I can not peel off with Hot Air Pencil or soldering iron that I have now.
Everybody solder, How are you peeling off?
PostPosted: January 11th, 2017, 6:25
Thanks Nick for sharing compatible PCB info.
today i have all data saved. i Have moved the rom-chip 602 to donor PCB :D :D
Frank
PostPosted: January 5th, 2020, 20:49
Nick_CT wrote:
This is probably old and obvious news, but just had to swap heads on a USB MQ01UBD100. The SATA PCB from the MQ01ABD100 head donor seemed a good match for SATA conversion.
USB PCB: G003250A
SATA PCB: G003138A
MCU: 88i9317-RAI2
Conversion worked fine.
So, i have one of USB MQ01UBD100, and found donor PCB SATA PCB from the MQ01ABD100. Do i still need to swap BIOS? Or can i it simply work by switching PCB?
PostPosted: January 6th, 2020, 3:57
shahgm63 wrote:
USB PCB: G003250A
SATA PCB: G003138A
MCU: 88i9317-RAI2
Must
A Recovery Service In Turkey . Veri Kurtarma Türkiye https://www.digitalverikurtarma.com
Donor Drives hdddonormarket.com
PostPosted: May 20th, 2020, 22:01
Hi, everyone,
I have a couple questions about this specific drive and if you think a new board would help.
Out of nowhere the drive just stopped working. It was fine one day, and the next it is just dead. The drive doesn't light up when I connect it to a computer, no sounds, OS doesn't recognize it. I tried different cables and different computers.
I was hoping that the interface is just bad and the drive is OK. I just had to do a data restore on a seagate drive and it cost $700. I really don't want to have to do it again.
Do you think this sounds like a bad board? I tried to remove it to make sure everyone was connected, but one of the screws is stripped and couldn't get the all off. Any tips on dealing with a stripped screw when they are so small?
Thanks for any help;
PostPosted: May 21st, 2020, 3:00
There are two fuses near the USB port.
PostPosted: May 21st, 2020, 22:19
Thanks for reply. I'm taking from that that you think one or both of the fuses might have blown?
Are they the two yellowish looking pieces that I have boxed out in green on the attached image?
Do they just pop out to replace? They look like they were soldered in.
Thanks again
PostPosted: May 21st, 2020, 23:35
Here they are:
Users browsing this forum: No registered users and 69 guests
