 Post subject: Hdd drive not spinning up on my system
PostPosted: November 20th, 2014, 2:19
Hello to everyone.
I have a strange problem with my system.
A few days ago the hdd (samsung spinpoint f3 sata 2 1tb) did not start.
The system starts ,enters Bios but it doesn`t detect the hdd drive.
I tried the following:
1.Another Sata power cable (the psu is corsair tx650),another sata port,another sata data cable,reset bios,change from ide to ahci and reverse but nothing worked.
2.Tested the hdd on a second system and it works perfectly.
3.tested on the second system my PSU and hdd the result : everything works.
4.changed the psu of my system...but the hdd angain doesn`t spin up.
I have to mention that i had problems before with the system,meaning that i had sometimes no video signal at start,sometimes short continous beeps at the motherboard speaker (gigabyte h55-ud3h), meaning in the manual ``power error``.
So can i conclude that the sata controller of the motherboard may be dead?
Thank you
 Post subject: Re: Hdd drive not spinning up on my system
PostPosted: November 20th, 2014, 2:58
"SATA 3.0 (6Gb/s) devices may not be detected on Intel 5 series and mobile 5 series southbridge"
https://ata.wiki.kernel.org/index.php/K ... outhbridge
Problem description
Handshake between SATA device and SATA controller on Ibex Peak PCH outhbridge may not complete after booting from ACPI G2, G3 state or after resuming from ACPI S3, S4 state and thus device will not down-shift to 3Gb/s speed resulting in undetected device.
Root cause
Southbridge erratum #21.
Affected southbridge
3400, 3420, 3450, B55, H55, HM55, P55, PM55, H57, HM57, Q57, QM57, QS57
Solution
None, reset the system until device is detected.
PostPosted: November 21st, 2014, 1:56
it is a SATA 2 motherboard with a SATA 2 hard drive.
They worked together fine for almost 4 years.
Users browsing this forum: Google Adsense [Bot] and 39 guests
