lcoughey wrote:
I'd say that you have a 90% chance of completely killing the drive, losing the data permanently. If you go to a professional data recovery lab (one that is reputable), there is a 99% chance that they will recover the data, if it is even recoverable at all.
I might have to do that in the end.
data-medics wrote:
However difficult you're assuming that a headswap will be, multiply it times 100. There's a reason why data recovery companies are charging as much as they do. Even if you successfully move the heads over without killing them (unlikely without a lot of experience) you'll still need pro tools to get the drive really working and extract the data.
And FYI - Salvation Data is a big joke, their tools just don't work.... period.
Really? The fact that the admins have created a forum here made me think that they are a pro company. As far as I can see the only issue with moving the heads is not letting them scratch the surface of the drive while beeing removed and not touching with each other. As for the second part... I 've seen people using home made tools. Like plastic parts from product covers etc.
I will take the disk for diagnostics in a pro company and then I will make my decision.
