There appear to be two problems.
The first is that you have removed the drive from its enclosure and have exposed its native 512e sector size, whereas inside the enclosure it appears as a USB mass storage device with a 4KB sector size. Your OS now sees a "4KB file system" on a 512e physical drive.
The second problem is that your computer's SATA driver appears to have a 32-bit LBA limitation. This accounts for the 802GB capacity.
You need to reinstall the HDD inside its enclosure.
_________________ A backup a day keeps DR away.
