 Post subject: Seagate 500 gb Harddisk - pcb board 100535704 REV C burned
PostPosted: December 19th, 2014, 11:40
My Harddisk, 500 gb seagate with pcb board 100535704 REV C got burned at a diode near power adapter. Its not detecting at all and not running also.. i couldn't get a replace board FOXCONN PCB 100535704 REV C at my place.. can i use some other compatible board.. i tried changing to FOXCONN 100535704 REV D PCB board..at that time the hard disk runs..but not detecting in both bios or disk management. is there any way that i can retrieve the data from...i need it very badly...
 Post subject: Re: Seagate 500 gb Harddisk - pcb board 100535704 REV C burn
PostPosted: December 19th, 2014, 11:59
you can simply try to change your burnt diode
http://www.hpwlab.com
PostPosted: December 19th, 2014, 13:35
If you're using a good power supply connected to a UPS you can simply remove the D3 or D4 diode and the pcb may work. TVS diodes are used to absorb over voltage from power surges. Without them the drive will be unprotected (thus the reason for the good power supply and UPS) but it likely might work. Just don't trust it for future use, copy the needed data out and junk it.
PostPosted: December 19th, 2014, 17:23
Is this your board?
http://ep.yimg.com/ay/yhst-144375849714 ... 1155-7.gif
If so, then the burnt components are probably inductors.
Users browsing this forum: No registered users and 52 guests
