 Post subject: ST1000DM003 Problem
PostPosted: April 13th, 2015, 1:12
When this hdd connected via SATA port, system did not see any of the connected HDDs.
If i removed the said hdd then all other connected hdds are seen by BIOS.
is it PCB or BSY problem?
 Post subject: Re: ST1000DM003 Problem
PostPosted: April 13th, 2015, 1:14
Likely neither based on the specifics within your question. Use the search function for tons of info on this series.
PostPosted: April 13th, 2015, 1:15
most likely PCB
edit: if it's causing the computer not to turn on
PostPosted: April 13th, 2015, 1:26
Computer turn on without problem.
But system(BIOS) did not seeing any device connected in SATA Port (HDD) when the affected hdd connected. if that hdd removed BIOS sees all other hdd
PostPosted: April 13th, 2015, 1:40
Need more details...
How do you think it got damaged?
What is the drive's current physical behavior?
PostPosted: April 13th, 2015, 1:43
ouch DM series drive
PostPosted: April 13th, 2015, 2:31
Spindle motor Runs and NO strange sounds.
PostPosted: April 13th, 2015, 2:35
Bingo
PostPosted: April 13th, 2015, 10:19
Typical DM behaviour
Digitalsupport Data Recovery
https://digitalsupport.dk
Users browsing this forum: No registered users and 35 guests
