Post new topic Reply to topic  [ 55 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: ST1000LM025 conversion
PostPosted: May 10th, 2015, 10:35
osity wrote:
The adaptives that were transferred were on the st1000lm25 (source) to the 24 model. Out of curiosity , How did you determine that adaptives are not on the ROM on the 24.
Because it's a Samsung drive. Samsung drives doesn't store adaptives on ROM. You just need to match the ROM code version with the Overlay version and it will work, you don't have to worry about adaptives that are exclusive to the drive (like for example on ROYL drives).
http://www.hddoracle.com/viewtopic.php?f=116&t=1085
osity wrote:
If ROM was damaged I don't think it would spin up the source drive, which it does.
Ok, i was thinking that the original (damaged) drive didn't spin at all to start with.
osity wrote:
I have contacted other pros which includes ace labs, and I keep hearing that they've never seen this drive before.
Maybe you should contact someone else then.
PostPosted: May 10th, 2015, 11:01
Spildit:
It spins up so ROM should be good. https://www.youtube.com/watch?v=to3LRLT5ozY
I'm thinking its firmware related, that's why I'm trying to access terminal.
PostPosted: May 10th, 2015, 12:00
Fzabkar: interesting, your search for the ST 1000LM024 brought up a totally different PCB . Here is what the source drive looks like.
I do have the bf41-00354a board you suggested in stock but the MCU does not match source. It's same as the other pcbs I've tried. It won't spin up even with the hda blocked.
Source pcb:
PostPosted: May 10th, 2015, 14:41
I misread your earlier post, so my suggestion for a match was based on the wrong MCU part number. However, the reasoning was correct. Please go with the other suggestions.
As for your Youtube uploads, why not post a terminal log?
PostPosted: May 10th, 2015, 17:43
I'm currently incapable of producing terminal logs from this drive. That's why I wanted to convert it. If you're referring to my YouTube uploads, those would be from other jobs.
I'm going to check my drive library for the pcb suggested earlier.
Would be nice if I knew which models used that board, that would save a lot of time sorting through the 100 or so seagates 2.5" I got. :cry:
Perhaps they can be filtered by date to narrow the legwork...I.e 2012-2014
PostPosted: May 10th, 2015, 17:56
A spinning Samsung drive should produce a terminal log, unless the latest designs are different from the earlier ones. There are two Tx/Rx test points. You only need to solder 3 wires. Pretty basic stuff.
PostPosted: May 10th, 2015, 19:51
Fzabkar;
I've only ever needed 2 wires for it to work in the past, pins 3&4.
Is your 3rd wire a ground?
PostPosted: May 10th, 2015, 19:53
Some people report random garbled characters until they add the ground wire.
PostPosted: May 10th, 2015, 20:20
Yep, I get those sometimes :)
PostPosted: May 11th, 2015, 2:00
100% true
PostPosted: May 12th, 2015, 19:53
quote="Spildit"
"Samsung drives doesn't store adaptives on ROM. You just need to match the ROM code version with the Overlay version and it will work,"
Kevin over at PCB Solution stated the following about the Rom chip:
" this is the only chip that holds any unique data on the board"
So someone must be incorrect. I'll test this with a random donor by swapping ROMs to see if they ID. It's so easy to do that it seems silly not to do it every time anyway.
PostPosted: May 13th, 2015, 2:17
Data in ROM on Samsung isn't unique to the drive, unlike WD, Toshiba, most ahitachi and later Seagates.
PostPosted: May 13th, 2015, 3:58
osity wrote:
quote="Spildit"
Dump the chip and check the dump with hex editor. Do the same with a WD ROYL ROM. See the differences..
PostPosted: May 28th, 2015, 22:01
Hi, just reporting back with my finding about the comment below.
"Samsung drives doesn't store adaptives on ROM."
It seems that the PC vendor that recommended the ROM's be swapped was correct at least for that model anyway.
I eventually sourced a PCB and the adaptives did have to be transferred otherwise the drive would not detect.
PostPosted: May 29th, 2015, 2:31
What do you understand by the term, "adaptives"?
PostPosted: May 29th, 2015, 3:15
Vendor was correct, ROM had to be transferred.
You are wrong, "adaptives" were not transferred. There aren't any in the Samsung ROM.
As Franc suggests, ROM version is NOT the same as "adaptives". You are getting the terminology mixed up.
PostPosted: May 29th, 2015, 9:39
1 - Samsung drives don't have adaptives on ROM.
2 - ROM version on the new PCB must be the same as ROM version on the native PCB, because ROM on pcb must match overlay on platter (MC).
3 - You have to swap ROM chip if ROM version on the new PCB is not the same as ROM version on native PCB. It's not exclusive adaptives that are swaped it's just to match the ROM version without looking for a PCB with the same ROM version as yours.
4 - If you can't find same ROM version and you don't want/can't swap chips you can match ROM with overlay by changing overlay to match ROM instead of matching ROM with overlay :
PostPosted: May 29th, 2015, 15:15
fzabkar: By 'adaptives' I'm referring to G&P lists, LBA, model#, Serial#, some servo details, and any other unique info that is stored on the "ROM" chip pertaining to that particular drive that allow it to come ready. Perhaps I've used the wrong terminology. Is this the case, how do you define the term?
..... I've also not clearly understood why everyone calls is a "ROM" when it can be written to and modified.
Spildit: how are you identifying your ROM version. (visually on a chip?) I'd like to verify your #2 statement on this last recovery I just finished.
I'm not familiar with your #4 statement, I've never needed to do anything with overlays.....sounds interesting.
PostPosted: May 29th, 2015, 15:20
I'm not going to comment any further on this, sorry.
No point on keep trying to explain anything when you doubt what i'm saying and are assuming that a g-list and a p-list would be stored .... on ROM ...
Well, keep on reading and learning.
Regards.
PostPosted: May 29th, 2015, 15:26
Example of firmware modules (MC) on PLATTERS (NOT ON ROM) :
You will be able to see defect list there.
ROM on SAMSUNG doesn't store exclusive adaptives for the drive. Period.
Users browsing this forum: Google Adsense [Bot], imtra84 and 27 guests
