Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
 Post subject: Re: 3.5" Toshiba's
PostPosted: November 23rd, 2019, 14:31
Remove D703. Hopefully that's the only problem.
Measure the resistance between the diode's pads in-circuit. Also test the fuse ("4").
If you want to minimise your risks, replace the PCB and transfer the serial flash memories. Be careful, as you must not damage them.
PostPosted: November 24th, 2019, 13:01
Hello fzabkar,
you're amazing. Removing the diode D703 fixed the HDD. Thank you so much!
First I was worried removing the diode, because in an earlier post it was mentioned that this diode isn't a TVS. So I was not sure if I was allowed to simply remove it.
Note:
I also measured fuse "4" and it was still working. The diode's pads in-circuit showed the same results, as measuring directly on the components.
Users browsing this forum: Bing [Bot], Google [Bot] and 35 guests
