 Post subject: SAMSUNG HDD "Conceptual Case"
PostPosted: January 5th, 2016, 8:36
I've received a case
In LABEL: HD502HJ - 500GB
In Shape/Size/Weight/PCB - I believe it's 750GB or 1TB HDD which was actually refurbished and resold with new label of 500GB Model.
I believe it's possible to identify if it's 750GB/1TB model actually. Later issue - I can't get the idea so far - identifying the exact model.
Problem of the HDD:
As I identified, it's a PCB + ROM issue.
Unfortunately, the ROM can't be read by my external programmer MINIPRO - it produces some error "at this moment, I can't remember the error, can be updated later."
Fact is - this one is a REFURBISHED HDD.
Question:
Do you have any IDEA how to DEPOP head on SAMSUNG HDD? Where to get the specific info regarding head map in ROM/Module
At this moment, my tendency is preparing a DONOR HDD with similar config for the problematic HDD.
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: SAMSUNG HDD "Conceptual Case"
PostPosted: January 5th, 2016, 13:00
I guess my question would be: If you can't even read the ROM with your equipment, how do you expect to modify and write it back to the PCB?
If you could at least post some more info about the drive, or post the ROM code would help I suppose.
Or is this case just "Conceptual" and not a real case??? I'm confused. :?:
PostPosted: January 5th, 2016, 15:16
It's a real case. I was making an IDEA in mind with a plan that the DONOR overlay will be copied to PATIENT so that the DONOR ROM can match and proceed.
With this idea, I am thinking the need to prepare a DONOR first - THATS WHAT I MEANT CONCEPTUAL
At this moment, ROM reading is not possible, I'll try to read this one with other PROGRAMMER if this one be really READ. Regarding the ROM chip - it's well supported by the Programmer I use, but the PATIENT ROM is not reading for some reason.
REGARDING THE HDD:
LABEL: HD502HJ (500GB)
PCB: BF41-00353A (Indicates 750G/1TB)
__________
THANK YOU
SHAHI
PostPosted: January 5th, 2016, 15:33
Here is the LOG it produces with DONOR PCB + ORIGINAL ROM
Apple Macpro RAID connect phy calibration
PLL locked!
ChipRev = 63B0
*PA VID=0000 PN=0004 Rev=0002- 785x Found
U
S_0
RV En Sensor Circuit
En Shock Sensor Circuit
SO_1
SpinStartUp: mcSpinRPM = 0
RPM at Handoff: 585
Temp : 24 degC
<MDL_SVO_SpinCheckReady_1> mfAccelRty = 1    RPM = 46
SpinStartUp: mcSpinRPM = 519
RPM at Handoff: 742
Temp : 24 degC
<MDL_SVO_SpinCheckReady_1> mfAccelRty = 2    RPM = 154
SpinStartUp: mcSpinRPM = 667
RPM at Handoff: 836
Temp : 24 degC
<MDL_SVO_SpinCheckReady_1> mfAccelRty = 3    RPM = 175
SpinStartUp: mcSpinRPM = 724
RPM at Handoff: 869
<MDL_SVO_SpinCheckReady_2> SpinAccelFail    RPM = 869
SO_2 C=0,A=3,S=1,RPM=869
RPM at Handoff: 842
Temp : 24 degC
<MDL_SVO_SpinCheckReady_1> mfAccelRty = 1    RPM = 176
RPM at Handoff: 715
Temp : 24 degC
<MDL_SVO_SpinCheckReady_1> mfAccelRty = 2    RPM = 218
SpinStartUp: mcSpinRPM = 611
RPM at Handoff: 792
Temp : 24 degC
<MDL_SVO_SpinCheckReady_1> mfAccelRty = 3    RPM = 204
SpinStartUp: mcSpinRPM = 673
RPM at Handoff: 839
<MDL_SVO_SpinCheckReady_2> SpinAccelFail    RPM = 839
SO_2 C=0,A=3,S=2,RPM=839
RPM at Handoff: 813
Temp : 24 degC
<MDL_SVO_SpinCheckReady_1> mfAccelRty = 1    RPM = 203
SpinStartUp: mcSpinRPM = 707
RPM at Handoff: 858
Temp : 24 degC
<MDL_SVO_SpinCheckReady_1> mfAccelRty = 2    RPM = 211
RPM at Handoff: 729
Temp : 24 degC
<MDL_SVO_SpinCheckReady_1> mfAccelRty = 3    RPM = 181
RPM at Handoff: 578
<MDL_SVO_SpinCheckReady_2> SpinAccelFail    RPM = 578
SO_2 C=0,A=3,S=3,RPM=578
SO_3 R Sp Err
SpinUp Fail
VOP!
PK_4   C:     0 H:0
LED 1703
LED 1703
with DONOR PCB + ROM = it produces exactly same message on DONOR HDA
__________
THANK YOU
SHAHI
PostPosted: January 5th, 2016, 15:35
FWIW, if you examine the SpinPoint F3 AMD SB850 firmware update, you will find massive differences in the ROM code for the HD103SJ and HD502HJ.
Samsung F3 and F3EG Firmware Patch/Update:
http://knowledge.seagate.com/articles/e ... Q/223631en
PostPosted: January 5th, 2016, 15:40
By the way, the DONOR PCB I used from HD103SJ (1TB), the PCB + Original ROM was tested on 1TB DONOR HDD.
Yes, HD502HJ - is 1 platter/2 heads
But the HDD I received, according to weight/shape/PCB - it must be a 2 Platter 3/4 heads
__________
THANK YOU
SHAHI
PostPosted: January 5th, 2016, 16:11
Is this your situation?
    donor PCB + donor ROM + donor HDA -> SpinUp OK
    donor PCB + patient ROM + patient HDA -> SpinUp Fail
    donor PCB + patient ROM + donor HDA -> SpinUp Fail
If you return the donor ROM to the donor PCB, does the donor HDA still spin up?
What was the failure mode of the patient PCB? Any terminal log?
PostPosted: January 5th, 2016, 16:21
donor PCB + donor ROM + donor HDA -> SpinUp OK - YES (DONOR IS 1TB HD103SJ)
donor PCB + patient ROM + patient HDA -> SpinUp Fail - YES, SpinUp fails
donor PCB + patient ROM + donor HDA -> SpinUp Fail[/list] - YES, SpinUp fails
If you return the donor ROM to the donor PCB, does the donor HDA still spin up - Can update this one tomorrow.
The Patient PCB was received DEAD.
__________
THANK YOU
SHAHI
PostPosted: January 5th, 2016, 16:43
Measure the voltages at the coils on the patient PCB. You should be able to do this even in the absence of a ROM.
http://www.users.on.net/~fzabkar/HDD/HD103SJ_regs.jpg
If the Vcore or Vio voltages are missing, then the motor controller would be a likely suspect. If the motor controller failed, then it could be that the motor has a bad winding. A bad winding could damage a donor PCB.
I would measure the resistance between each pair of motor terminals.
If one winding is bad, then there may be a way to increase the motor current to compensate, but I would try this on the donor HDD.
PostPosted: July 10th, 2019, 14:51
I have same issue.
This drive for my training. Not client case.
HM641JI
Pcb BF41 00306A
PCB died. Some chips burned.
I removed bios chip and soldered to working donor PCB.
Terminal log :
Apple Macpro RAID connect phy calibrationPLL locked!ChipRev = 63B0
Drive doesn't spin.
I tried another drive with same pcb. Same , only ChipRev = value different. And doesn't spin.
Again soldered original rom to donor. Working normal. It's about patient drives ROM
I couldn't find anything with Google.
A Recovery Service In Turkey . Veri Kurtarma Türkiye https://www.digitalverikurtarma.com
Donor Drives hdddonormarket.com
PostPosted: July 10th, 2019, 17:43
Can you show us the markings on each of your patient and donor MCUs?
http://www.hddoracle.com/viewtopic.php?f=59&t=205
PostPosted: July 11th, 2019, 6:56
Left donor right patient
Different MCU label
Could be not matching PCB?
PostPosted: July 11th, 2019, 15:40
I knew I’d seen that message before! :-)
Some trawling of this forum.....
https://forum.hddguru.com/viewtopic.php ... LL#p153812
PostPosted: July 11th, 2019, 15:47
The MCUs appear to be matched (both "B0").
PostPosted: July 11th, 2019, 16:24
Looks like some of us cannot access this exclusive part of the forum.
PostPosted: July 11th, 2019, 19:51
That's the [cryptic] message you get when you try to access any deleted post.
PostPosted: July 11th, 2019, 22:33
Giod to know. I still think they are out to get me :-)
Users browsing this forum: Google [Bot] and 22 guests
