Post new topic Reply to topic  [ 49 posts ]  Go to page 1, 2, 3  Next
 Post subject: HTS541010A7E630 (NEWEST MODEL)
PostPosted: January 5th, 2016, 15:45
Confusing Head Map Info:
The HDD has no ID, ready in a sec
What would you say?
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: HTS541010A7E630 (NEWEST MODEL)
PostPosted: January 5th, 2016, 19:07
Corrupted NVRAM perhaps???? Have you tried editing it to be something more typical like 00 01 02 03 ?
More likely I'd guess it's just not properly reading the headmap from the family given how new it is.
PostPosted: January 5th, 2016, 19:18
Can you upload the ROM/NVRAM? I can test the checksum for you.
PostPosted: January 6th, 2016, 10:24
Yes, I changed the HEAD Map like 01 02 03 04, still no id, it ids by utility (Unknown family)
Here is the attachment
HGST HTS541010A7E630-SE0OA4A0-S00000SSGBJLEF.rar [136.44 KiB]
Downloaded 330 times
__________
THANK YOU
SHAHI
PostPosted: January 6th, 2016, 14:56
The checksum is OK.
C:\>xorchksm -16 nv-ram.nvr
nv-ram.nvr: XOR16 checksum = 0x0000
This looks like the head map:
00000690                          00 01 02 03 0F 0F 0F 0F
000006A0  0F 0F
The software is expecting to find it here:
00000680              20 00 E8 03 E3 78 05 04 0A 00
PostPosted: January 6th, 2016, 15:14
So, the tool is not working properly to access the Head Map correctly.
__________
THANK YOU
SHAHI
PostPosted: January 6th, 2016, 15:23
That's right. You probably corrupted your NVRAM. Can we see what it looks like now?
PostPosted: January 6th, 2016, 16:45
No, I didn't corrupt the NVRAM. It came this way. I went to Edit NVRAM to see its status. And I see this invalid headmap and posted. I tested by inputting n saving 00 01 02 03 0F and so on to see hdd status. Found Same behaviour. And the values were inputted back to original. After I posted the nvram, its remained same so far. No furthere task is done
__________
THANK YOU
SHAHI
PostPosted: January 6th, 2016, 16:55
You misunderstood me.
I was suggesting that the original ROM and NVRAM were OK and that you corrupted the NVRAM when you edited the wrong "head map" bytes.
PostPosted: January 6th, 2016, 17:07
Ok.got it.
I restored back the bytes to its original status (as attached nvram), and the original one shows like the op picture.
Now the hdd is in its original form it came.
So, if i m not wrong, according to your analysis, the tool is reading incorrectly this one. N in the original state the rom/nvr is ok.
What would u suggest?
__________
THANK YOU
SHAHI
PostPosted: January 6th, 2016, 17:15
Try to plug only PCB or desolder NV-RAM and read on external programmer.
But I think it is head problem.
Sistrum Data Recovery
http://www.sistrum.mk/en
PostPosted: January 6th, 2016, 17:22
I have no idea what to do. All I'm suggesting is that perhaps your model has a slightly different structure for the NVRAM.
FWIW, here are the head map bytes from an HTS725050A7E630:
00000680              00 01 0F 0F 0F 0F 0F 0F 0F 0F
They appear to be at the same location where your tool expects to find them in your HTS541010A7E630 dump. Perhaps you have selected the wrong family?
PostPosted: January 6th, 2016, 18:10
HTS541010A9E680 head map
00000680              00 01 02 03 0F 0F 0F 0F 0F 0F
PostPosted: January 6th, 2016, 18:37
Seems like it could be a power up in stand-by feature set.
PostPosted: January 6th, 2016, 19:02
The ROM contains the model number, so wouldn't the drive still ID with a limited set of Identify Device data?
    HTS541010A7E630
    APPLE HDD HTS541010A7E630
PostPosted: January 6th, 2016, 19:11
    HTS541010A7E630
I don't remember ever getting a proper ID from a Hitachi with power up in standby.
PostPosted: January 6th, 2016, 19:21
The ATA standard specifies that a PUIS drive should respond to the Identify Device command with a partial ID, so you should still see something, even if most of the fields are blank. Of course it won't be a full ID because most of the data will be on the platters.
Anyway why isn't the tool reporting that PUIS is enabled, if that is indeed the case?
PostPosted: January 6th, 2016, 19:44
7.16.7.2 Word 0: General configuration
If the device is an ATA device, then bit 15 shall be cleared to zero.
If bit 2 of word 0 is set to one, then the content of the IDENTIFY DEVICE data is incomplete. This may occur if the device supports the Power-up in Standby feature set and required data is contained on the device media. The content of IDENTIFY DEVICE data word 0 and word 2 shall be valid.
7.16.7.4 Word 2: Specific configuration
Word 2 shall be set as defined in table 47.
Table 47 - Specific configuration
Value   Description
37C8h   Device requires SET FEATURES subcommand to spin-up after power-up and
        IDENTIFY DEVICE data is incomplete (see 4.14).
738Ch   Device requires SET FEATURES subcommand to spin-up after power-up and
        IDENTIFY DEVICE data is complete (see 4.14).
8C73h   Device does not require SET FEATURES subcommand to spin-up after power-up
        and IDENTIFY DEVICE data is incomplete (see 4.14).
C837h   Device does not require SET FEATURES subcommand to spin-up after power-up
        and IDENTIFY DEVICE data is complete (see 4.14).
All other values Reserved.
PostPosted: January 6th, 2016, 21:34
EDIT
Nop
00000DD0                 00
PostPosted: January 6th, 2016, 23:08
Hmm, I just noticed a pattern that looks like it might not be a concidence.
00000DC0                                      10 32 FE 76
00000DD0  98 BA DC 54
If you swap the nibbles in each byte, and rearrange the byte order, you get ...
    01 23 45 67 89 AB CD EF
The same pattern appears in other NVRAMs.
Users browsing this forum: Google [Bot] and 27 guests
