 Post subject: ST3000DM001 isn't recognized any more (HDD LED stays on)
PostPosted: March 6th, 2016, 14:19
Hi!
I have a problem with my Seagate Barracuda Drive. Specs:
  • Model ST3000DM001
  • PN: 9YN166-302
  • FW: CC4C
  • Date: 12293
This morgen, I got to my PC (running windows 7 Pro), and the HDD LED was shining all the time. The pc didn't react.
I resettet it, but it was some kind of slow (slow boot screen, etc...). It bootet windows up, but the HDD wasn't recog-
nized by the system. It was like it wasn't connect to the mainboard.
I tried to connect it over an SATA-USB adapter, but with no success. The activity led of the adapter was on too all the
time. I listend to the drive acoustics, but I sounded correct. Do clickering or unusual sound.
What can I do to get back access. Help would be much eppreciated!
 Post subject: Re: ST3000DM001 isn't recognized any more (HDD LED stays on)
PostPosted: March 6th, 2016, 15:08
it seems you have used english translation, anyway did you mean that drive is spinning fine without any abnormal clicking or spin down ??
if yes you need a ttl adapter to diagnose it further, provide terminal log ere hso someone can guide you to find out the problem.
since it is DM series, i would suggest to send to a DR company.
good luck.
Data Recovery Pakistan
PostPosted: March 6th, 2016, 15:18
First of all: Thanks very much for your answer. I'm feeling a little bit lost with my problem.
No. That was my german HDD englisch. I'm sorry for that. :?
I meant that when it starts, it sounds like I'm expecting a HDD to sound... Nothing abnormal.
Do you mean such kind of adapter? klick
What's special about DM series? Can you recommend a company?
MindMergepk wrote:
good luck.
PostPosted: March 7th, 2016, 4:36
well, seagate is facing a class action law suit over its 3TB drives failure rate, read here :
http://www.pcworld.com/article/3028981/ ... rates.html
DM series are very complicated when it has physical problem, by your description it seems that you drive has some Firmware, Bad Sector problem, could be heads also, but needs to be diagnosed first.
yes the ttl adapter is correct as per your link, this is what you need. i have seem couple of German member here on this forum, atleast i know that they are equipped with proper tools. Wait a while someone who know any German reputable member should recommend you.
PostPosted: March 7th, 2016, 4:51
The fact that you're not hearing any abnormal sounds, is very encouraging.
You *might* be lucky and it's just a fw related issue, otherwise... well, you don't want to know.
As MindMergepk said, DM series are a PITA and many pros find them difficult to recover.
Their overall quality is crap, and I'm being generous here.
Viel Glück
PostPosted: March 9th, 2016, 5:39
Ich würde keine Selbstversuche an einer Seagate ST3000DM001 unternehmen. Diese Festplatte sind relativ tricky in der Datenwiederherstellung - auch für Experten.
Wir kommen aus Augsburg und bieten eine kostenlose Abholung oder Einsendung der Festplatte sowie eine kostenfrei Diagnose deiner Festplatte.
Bei Fragen kannst du uns gerne jederzeit kontaktieren. https://www.day1data.de/kontakt
I wouldn't try anything DIY on a Seagate ST3000DM001. These drives are tricky to recover.
We are in Augsburg, Bayern.
We pickup in Germany and evalutate your drive for free.
Feel free to contact us if you would like.
Web: https://www.day1data.de
PostPosted: March 12th, 2016, 4:11
OK. I have now a serial Adapter. I think, I will give one try a chance that the pro's here can say wheter
I should keep trying myself or I should send in the drive direktly.
So is there "a way to do" or a tutorial? Especially for Seagate drives? I want to run the drive as short
as possible...
thanks in advance!
Tipps auf deutsch sind auch willkommen :wink: Dann wäre es aber nett, wenn der oder diejenige ein
wenig am Ball bleibt.
Danke im Vorraus!
PostPosted: March 12th, 2016, 5:58
Wenn eine Festplatte bereits Probleme hat/macht, dann ist es - sorry - absolut
unlogisch, diese mittels eines USB-Adapters weiter zu "malträtieren".
Jede Aktion (Herumdoktern) mit einer defekten Festplatte kann zu weiteren
Datenverlusten führen.
If one is already faced with problems on a drive, its unlogically to ill-treat it
with a USB adapter
each action (potter around) with a defect drive might cause further data loss.
PostPosted: March 12th, 2016, 12:57
Ok. Ihr hab mich überzeugt. Ich schaue mich mal nach Datenrettungsdiensten um...
Wie ärgerlich, dass man sich nicht an der Sammelklage in den USA gegen Seagate
beteiligen kann :(
PostPosted: March 13th, 2016, 1:07
beteiligen kann :(
I Would suggest you try day1data .He is active on all professional forums and knows his work .If he gets hold of your drive atleast he will give you a idea whats the issue and how much he plans to do this job for .You want him to do it or leave it will depend on you and him
Users browsing this forum: Google [Bot] and 68 guests
