Post new topic Reply to topic  [ 46 posts ]  Go to page 1, 2, 3  Next
 Post subject: 0xC801 = DCO_FREEZE_LOCK_IN_PLACE - SA Format not completed.
PostPosted: July 21st, 2016, 9:14
Hey, today, i have very strange case, because while format SA,
I get the error: 0xC801 = DCO_FREEZE_LOCK_IN_PLACE, and format SA not completed.
Drive: WD2002FAEX-007BA0 Mantis_PL_RE, FW: 00050016F/05.01D05
Log:
Action: Read Head Map............................................ OK!
Number of physical heads: 8
Number of heads in use: 8
Native head map: 255
Good head map: 255
File E:\HDD_REPAIR\SeDiv\WD2002Modules\0001.bin Load OK!
--------------------------------- Task Begin --------------------------------
Load External Resident File Dir
Number of File Entries = 456
------------------------------- Task Completed ------------------------------
HZ File Not Found!
HZ File Not Found!
HZ File Not Found!
HZ File Not Found!
Action: Read Flash............................................... OK!
Action: Reset Immediate.......................................... OK!
Action: Write Buffer Extended to permanent overlay buffer........ OK!
Module ID 0011 Load - OK!
Action: Write Buffer Extended to transient overlay buffer........ OK!
Module ID 001B Load - OK!
Write Code File - OK!
Load Data File C5 - OK!
Action: 4........................................................ OK!
Start: 01.18.23
Waiting for test to begin: = 30 seconds remaining until timeout
Start: 01.18.24
=========================   START   TESTS   ==========================
ARCO Run completed successfully!
Ecode Description= No Error
Action: Write Buffer Extended to PST Buffer...................... OK!
Start Self SA
01.53.10
Self SA - Running
01.53.10
01.56.12
Action: Check Module ID 0030..................................... OK!
Copy 0: 0030.............  OK
Copy 1: 0030.............  OK
Action: Check Module ID 0035..................................... OK!
Copy 0: 0035.............  OK
Copy 1: 0035.............  OK
Process Validation PASSED!!!
01.56.13
Action: Read Resident file: 0035................................. OK!
File 0035 is a new header format file.
Format Reserved Start
01.58.54
Action: Format Reserved Area..................................... Error: DCO_FREEZE_LOCK_IN_PLACE
02.01.29
I Used Sediv Repair tool(most power full soft), and WD marvel(very poor soft) in both cases error is the same, btw generated modules, are empty, no SA Bad Sectors in all Heads.
Moreover, drive is fully mechanical working, but Firmware, and ROM, Adaptives are incorrect.
 Post subject: Re: 0xC801 = DCO_FREEZE_LOCK_IN_PLACE - SA Format not comple
PostPosted: July 21st, 2016, 9:33
Any ideas for this case?
PostPosted: July 22nd, 2016, 6:33
Hi!
I have Sediv too!
Are you sure that HSA can write without any problem? If write heads are not stable enough, then you have SA error when try write.
PostPosted: July 22nd, 2016, 10:03
Hi
The drive is Firmware lock, that's why SA Format gives DCO lock Freeze error
Follow these steps, load 01 and 35, then power reset, and load all modules and make hdd in detection.
1. Use SA operation ---> SA Unlock wait for finish
2. Power reset
3. backup all firmware
4. Format SA
5. Repair DIR
6. Load all modules Except 01 and 35 on both copies.
Now you can do all operation what you want.
If you want to unlock Drive SA then you must need to edit 02 module.
For Example
Hdd family = Hubble_LT
open 02 module in hex view, goto offset 725 (offset 725 have value 01), before this offset you see value 01 D6 06 00 1E 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 01 00 01 00 09 0F 0F 0F 0F 0F 00 00 00 00 00 00 00 00
you need to change it to 01 D6 06 00 1E 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 01 00 01 00 09 0F 0F 0F 0F 0F 00 00 00 00 00 00 00 00
you need to change just one byte from 01 to 00 at offset 725.
For different families offset is little bit different , but bytes values are always same.
Waqas Ali
http://www.sediv.net
PostPosted: July 22nd, 2016, 11:20
saltwater wrote:
Hi!
I have Sediv too!
Hi Saltwater. Yes, all 8 heads read/write 3x runs test OK.
waqas_ali766 wrote:
Hi
2. Power reset
4. Format SA
5. Repair DIR
For Example
Waqas Ali
Hi Waqas, but problem shows then SA is Empty.
When Run SA Selftest, Selftest SA completed, New mods 30, and 35 generated are empty, so run Sa Format using Mod 35(in hdd, no external file) and after 3 min SA Format show: 0xC801 = DCO_FREEZE_LOCK_IN_PLACE.
PostPosted: July 22nd, 2016, 15:41
Yes its a fault of SA lock, mostly its appear in Denali drives.
You can use SA unlock function first then power reset and backup the firmware. then do all of your required process.
If it not helps then let me know
i will check it by remote
Waqas Ali
PostPosted: July 22nd, 2016, 16:35
IIUC, here is the general procedure for unlocking the SA.
The following example is for a Hubble_LT:
http://files.hddguru.com/index.php?action=downloadfile&filename=WDC%20WD3200LPVX-08V0TT5%2005.01A05%2006.3TJ%20-%20Hubble%20LT.zip&directory=Non-PC-3000%20firmwares/Western%20Digital/HUBBLE%20LT
Offset 0xAA defines the desired section of module 02, ie location 0x0708, size 0x0099. The next section begins at 0x07A1.
000000A0  45 00 DC 06 10 00 EC 06 1C 00 08 07 99 00 A1 07
00000700                          00 01 32 90 01 00 00 1E
00000710  00 00 00 64 00 00 00 64 00 00 00 64 00 00 00 64
00000720  00 00 00 00 04 00 00 00 02 00 00 06 00 00 00 FD
00000730  FF 00 00 FF FF 00 00 05 0A 0A 00 00 00 FD FF 00
00000740  00 FF FF 00 00 01 0E 00 00 00 00 00 00 00 00 00
00000750  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000760  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000770  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000780  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000790  00 00 00 00 00 00 00 00 00 00 D6 06 00 1E 00 00
000007A0  00                         ^^ change to 01 to unlock
PostPosted: July 22nd, 2016, 16:53
Sorry, I think that should have been "change from 01 to 00 to unlock".
PostPosted: July 22nd, 2016, 17:33
Waqas Ali
Well, My denali work fine ie SA self, and SA format without Error.
Only Wd Black have this problem in SA Format, so I click SA Unlock, and wait 5 sec, done. Drive perfect initialize, and must perform Full ARCO procedure, because Total Parameters are incorrect.
Now currently Run ARCO procedure, if done check your procedure.
Ok, so if done procedure ARCO, I will try to check yours suggestion.
PostPosted: July 22nd, 2016, 17:40
I believe that WDMarvel prints out all the sections of module 02. Otherwise you could use my program to do the same.
Usage:  MOD2DUMP filename [section_number]
C:\>mod2dump "\wd\firmware\hubble_lt\02.mod" 31
ROYL header found
Module 02 consists of 47 sections
Section 31     Length 153 bytes
Addr  00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
0000  00 01 32 90 01 00 00 1E 00 00 00 64 00 00 00 64  ..2........d...d
0010  00 00 00 64 00 00 00 64 00 00 00 00 04 00 00 00  ...d...d........
0020  02 00 00 06 00 00 00 FD FF 00 00 FF FF 00 00 05  ................
0030  0A 0A 00 00 00 FD FF 00 00 FF FF 00 00 01 0E 00  ................
0040  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
0050  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
0060  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
0070  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
0080  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
0090  00 00 D6 06 00 1E 00 00 00                       .........
MOD2dump.rar [85.08 KiB]
Downloaded 1117 times
PostPosted: July 22nd, 2016, 18:05
Yes, WD marvel show all contents in module 02, but is very poor if Regarding Arco seqence, or self test, or refurb.
As I write, If Arco procedure will done, i will check Yours suggestions.
Thank you very much Friends.
PostPosted: July 23rd, 2016, 4:50
Hi
Pikus_09 you problem is with SA lock, not a SED lock, 02 editing is used to unlock SED drives.
Editing 02 is used to unlock WD SED drives,
the WD SED drive cannot allow you to read and write firmware and rom,
in this condition , you have to show tv9 and tv10, then wait for ready status, after that remove short points, then auto detect and enter into the program
goto Main and click init hdd0, then goto dir manager, and press dir edit, then close it,
now backup 11 12 13 1b modules, backup 5c if hdd have.
now again power off, short tv9 and tv10 wait for ready status, load overlays, then remove short points
Init HDD 0 (this is used to initilize 01 module from hdd SA to ram, to get access on firmware )
Dir edit, then close it,
now open 02 in hex, find the byte, Hubble_lt locked hdd have offset 725, different families have different offsets. but the byte structure is same.
NOTE : If you need data then must backup original 02, and after repair you must write original 02 or make byte same to same as original.
Change this byte from 01 to 00 unlock the SED protection but encrypt the data (you can check sector 0 after and before edit 02 to understand properly)
This method is used for repairing only.
Waqas Ali
www.sediv.net
PostPosted: July 23rd, 2016, 5:21
waqas_ali766 wrote:
Hi
Waqas Ali
www.sediv.net
Ok, I will check your suggestion, if ARCO completed.
PostPosted: July 23rd, 2016, 6:01
Hi
Also if it show you msg DCO lock, in back ground its already finished the format Sa. you can check Regions after this format SA.
Waqas Ali
PostPosted: July 24th, 2016, 6:50
waqas_ali766 wrote:
Hi
Waqas Ali
Hi, checked your suggestions and SA format work in wd black, you are right, SA Unlock function first, then SA format.
But, self test scanning A lot of bad sectors in Head 0, and exceeds the limit of defects, and Self STOP, well i don't think that head 0 is BAD in User Area, because TEST all heads passed in Sa Area, and User area, well i think maybe Adaptives? What do you think?
PostPosted: July 24th, 2016, 7:15
waqas_ali766 wrote:
Hi
Waqas Ali
But, self test scanning A lot of bad sectors in Head 0, and exceeds the limit of defects, and Self STOP, well i don't think that head 0 is BAD in User Area, because TEST all heads passed in Sa Area, and User area, well i think maybe mismatch MJog Adaptives? What do you think?
PostPosted: July 24th, 2016, 7:41
Hi
Its not a MR jog problem.
The process of ARCO and SF is as follow
44 ARCO
6a
6f
6b or 290b or 2420
69 or 290b or 2420
46
4a
after this 4a hdd is ready for Self test, or manually testing of sector and adding into p-list, but without WRRO read and write test HDD never run format with P-list. and without WRRO read test hdd always full the SF logs.
B2 Write = WRRO write
B2 XMS
B2 READ = WRRO Read
D8 OR 3421
D1
Dd
DB etc
also you can use Sediv 5152 version and use ARCO+SA FULL TEST and choice the path of hdd original firmware. if will automatic repair all things and make hdd ready for you. auto start B2
if after B2 the logs still full, then its a fault of some zone, you can follow my video to find and cut faulty physical zone.
viewtopic.php?f=22&t=33829
Waqas
 Post subject: Lot of bad sector's while selftests, self test not complete
PostPosted: July 24th, 2016, 8:05
waqas_ali766 wrote:
Hi
44 ARCO
6a
6f
6b or 290b or 2420
69 or 290b or 2420
46
4a
B2 XMS
B2 READ = WRRO Read
D8 OR 3421
D1
Dd
DB etc
Waqas
Yeah, Arco 44 not work in sediv 5152 propertly New adaptives not work, Hdd restart after 5sec, can not calibrated.
6a = OK without error
6f = OK without error
2909 = OK without error, and TPI and Head Qual adjusted
69 or 290b or 2420 = My WDek not have test C8, because this test in implemented in 2909.
46 = Ok without error
4a = Ok without error
Then Run Self test, and check now if limit the defects will be filled again.
B2 XMS
B2 READ = WRRO Read
D8 OR 3421
D1
Dd
DB etc
Waqas
Yes, but I run selftest using oryginaly Factory Selftest script for WD Black for WD2002FAEX not in internet, understand?
Yes, I Use Sediv5152.
Btw, Waqas you had a WD Blacks in repair, or similar to My WDek?
PostPosted: July 24th, 2016, 9:05
Hi
I will Calibrate 44 mantis family 100% good.
if you are using function create and start calibrate, then it have a different procedure.
you must have to see my video on real case studies.
yes i repair all WD drives even the latest Hybrid drives SED locked.
By mistake i write 2909, its 290b
The original SF script in the hard disk is not perfect, because after hard disk manufacture factory remove many many important tests from the script.
you must have to use universal scripts. you can download from forum.
By the way from where you buy Sediv ?
Waqas Ali
PostPosted: July 24th, 2016, 9:26
waqas_ali766 wrote:
Hi
aaaa, that's it, IN my oryginal script not perfect, but in forum hddguru not found correct script for My Mantis_PL_RE, only Mantis_RE/DRAGFLY-4
Waqas Ali
Sediv I bought from the author Mr. DIV, He helped me in this my friend Vides. And if you have correct script for mantis_pl_RE send to my pm. Or this therard thank you friend for help.
