 Post subject: st3000dm001 mcmt corrupt
PostPosted: January 16th, 2017, 2:17
Hi so I have this drive and it was stuck with a fault reading the media cache causing the bsy error (sim 3005).
So I shorted the read channel to get read access jumped into level c and issued U1 U2 and U3 and now I have access to the drive and it shows in windows and I have dumped the drive contents successfully.
When the drive boots when connected to serial I get mcmt logs as below is this normal as I have not seen this before?
Boot 0x40M
Spin Up
TCC-0027[0x00026F7C][0x000273E8][0x00027854]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
TCC-0027
(P) SATA Reset
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
Reconstruction: MCMT Reconstruction Start
  Max number of MC segments 0A61
Nonvolatile MCMT sequence number 00000002
[RSRS] 0000
Reconstruction: Completed 0: HeadPtr was unwritten
[MCMTWS]
MCMainPOR: MCTStateFlags 0000002A  MCStateFlags 00000001
MCMainPOR: Feature Enabled...
PowerState = IDLE1
Is there a command to scan the SA for possible errors, I have already formatted the user partition and regenerated the defect lists but I did not know if this scans and regenerates the SA is this what autoscan does in the previous generation drives.
drugstoredir2014.com
Users browsing this forum: Google [Bot] and 143 guests
