 Post subject: How can I switch power between two hard drives using transis
PostPosted: January 16th, 2017, 3:40
Application
I have two hard drives that draw approximately 1.1A / 1.5A on their 12V and 5V power pins. I have several 2SA1020 PNP transistors which are rated 50V 2A and was hoping to use them to switch power between the two drives - the idea is that when the computer is off, opening or closing a switch would allow the 12V and 5V power sources to flow to just one drive. I considered using a MOSFET but the drives draw only a little power so it seems like these transistors would be ok, right? If not then please let me know what the main pitfalls are.
In my previous days of analog electronics tinkering this would have been a much simpler concept - the first thing that came to my mind was an automotive relay switch because it has a N.O. and N.C. leg and can direct power between the two of them. But I didn't find anything when I was searching for a '2-way mosfet' with NO and NC pins. I'd also just like to see if I can build this using the transistors I already have.
The idea I came up with for this was to have a switch which can ground the bases of the first two transistors used for drive 1 (D1), normally a pullup to 5V circuit, and use an NPN transistor as a NOT logic gate to invert the instruction to the second set of PNP transistors for the second drive (D2).
Here's what I've come up with:
Questions
Basically, what would be the best / easiest way to accomplish this?
The circuit I drew is the best that I can come up with. Will it work OK?
If not, what are the caveats I'm missing?
And, is there some other way that is much easier / simpler to achieve this?
ps: I'm mostly curious about the 'switching' part so I intentionally omitted additional components that I believe would be good to add in, such as those which would prevent switching if the computer was powered on, etc.
Users browsing this forum: LarrySabo and 28 guests
