 Post subject: Problem regenerating translator
PostPosted: May 11th, 2017, 20:48
when i put m0,6,3,,,,,22
i get this
Rst 0x08M
ASCII Diag
No HOST FIS-ReadyStatusFlags 2002A185mode
F3 T>
F3 T>m0,6,3,,,,,22
DiagError 0000500E Process Defect List Error
R/W Sense 00000002, R/W Error 841C0087, List Offset 00000000, List Index 0025617
7, File Error 000000D0
F3 T>
why? and what can i do?
 Post subject: Re: Problem regenerating translator
PostPosted: May 12th, 2017, 4:36
Banned User
Solution:
Read SYSTEM file 1B via terminal, remove all defects which has sign C, sign C = G to P transfer.
After that save it and write this system file again via terminal.
power reset
regenerate translator.
Done.
PostPosted: May 12th, 2017, 13:11
mmzhr wrote:
Solution:
power reset
Done.
Thanks, but: How can i do that in commands?
F3 T>?????What??
PostPosted: May 12th, 2017, 13:18
It's the same F3 arch drive that is clicking ???
No HOST FIS-ReadyStatusFlags - Translator is gone.
Process Defect List Error - Defect list is gone.
Also ....
If you use m0,6,3,,,,,22 G-List entries will be moved to Non-Resident G and you will end up with partial access problem if you have a F3 arch drive and then you will need something like PC-3000 "fork" method to fix (plus several days of waiting) and you are even more fuc*** up then you were before playing blindly with terminal commands ....
PostPosted: May 12th, 2017, 14:22
Also ....
ImageWhy Spildit why?
lol, this is another drive, i buyed it long time ago in 5$dollars, because the old owner have read in a program, HDD sentinel, his drive have 0 days live left :lol: . I used it during almost a year, until it broke in my brother computer. i´m triyng to fix it with my RS232 Tool.
PostPosted: May 12th, 2017, 14:45
Why did you use this ? - m0,6,3,,,,,22 ???
:shock: :shock: :shock:
Start by :
- Tell us the FULL MODEL OF THE DRIVE.
- Tell us if the drive click.
If you have TTL adaptor POST A TERMINAL LOG. Power on the drive with terminal opened and copy/paste log here.
But of course i will tell you the good news first !!! You will not be able to fix it so go and buy another $5 one :twisted: :twisted: :twisted:
PostPosted: May 12th, 2017, 15:41
Start by :
i'm at my work right now, when i get home i will tell you
PostPosted: May 12th, 2017, 16:16
Ok....
See you later then...
Users browsing this forum: beto, Bing [Bot], Yahoo [Bot] and 21 guests
