This is my everyday HDD
Here it works at his normal Speed 5400rpm. Sector 0 MBR it's fine so i can do a partition
This is SMART with Victoria
Toshiba MK7559GSXP 750GB im using it on a USB3.0 external case.
ATTENTION WHEN I TRY TO REMAP OR REALOCATE OR ANY OPERATION, I PLUG THE HDD DIRECTLY ON THE COMPUTER (SATA) I DO NOT USE THE USB3.0 ADAPTORThe problem: I'm using only 100GB (A partition of 100GB) of it's space because the other usable space is too unstable;When i copy a big file copyspeed get under the normal level (Normaly HDD FilewriteSpeed is 60-80/mbs on the first 100GB)
The 100GB Partition. Start at 11566800SECTOR. Ends 210756734SECTOR
I first tried a low level format so that way HDD Could realocate most bad sectors, (I don need a Cosmetic fix, this is my personal HDD, i don't care if SMART say there is reallocated sectors)
. I scanned again the HDD to find the most continue space on the HDD without bad sectors
This whas the SPEED TEST
Ugly isen't? SO i tryed anoter low level format to fix all thouse slow sector with MHDD ERASE
It toke several hours.After the low level format. Used HDD Regenerator, on REGENERATE ALL MODE. but the drive stays the SAME no Sector Recovered and slows sectors the same.
I tryed REMAP with several tools First MHDD, No result, VICTORIA says REMAP Failed!!!
WHY??AT THE MOMENT i'm using the first partition it works REALY FINE, i have to do it some fixes with CHKDSK to deal with the bad sectors, and thanks to the magic of the NTFS, now i'm using it.
The only problem is, sometimes apears some slow sectors who looks like bad sectors, and i have to use CHKDSK to correct that on the Partitiom i'm using.
I will like to know 2 things.
1- Why my HDD doasen't REMAP;REALOCATE; Security Erase?
2- How can i fix the others slow sectors on the drive to gain more usable Space?
