 Post subject: looking for adapter to samsung HS04THB
PostPosted: July 19th, 2017, 16:32
I need to read data on a hard drive (samsung HS04THB) from a dead Dell laptop, but have no idea about which adapter can connect it to other PC. Can anyone recommend one? Below is the specifications about the hard drive that I found on internet.
Thank you very much!!! :?: :) :?:
Capacity: 40GB
Speed: 4,200RPM
Interface Types: IDE ATA 1.8in ZIF
Form Factor: 1.8inx5mm
Sector Size: 512 / 512e
Average Seek Time: 15
Electrical Interface: EIDE Ultra ATA100 100MBps
On-Board Cache: 8MB
 Post subject: Re: looking for adapter to samsung HS04THB
PostPosted: July 19th, 2017, 16:42
Online
Read here :
viewtopic.php?f=1&t=33446
PostPosted: July 19th, 2017, 17:11
Thank you very much.
What is the name of the device?
I do not see usb port. What kind of port is at the another side?
Thank you again. Sorry for the ignorance.
PostPosted: July 19th, 2017, 18:51
The pictured adapter connects a drive with a ZIF or 44-pin IDE interface to a 40-pin IDE host controller. The adapter appears to incorporate a 3.3V LDO regulator for powering the ZIF drive. The 44-pin interface would be directly powered from the +5V Molex pin.
PostPosted: July 19th, 2017, 23:18
usually I wouldn't like to gang up adapters, but it MAY be possible to use this as well to get to your USB:
https://www.remotepro.com.au/products/i ... m_content=
as always, YMMV
PostPosted: July 20th, 2017, 9:21
https://www.sws-distribution.sk/delock- ... 55412.html
Can do an image search on Spildit's picture and get results. That's how I got the link above.
I believe Spildit's suggestion is good. This here looks very similar/identical to Spildit's suggestion:
http://www.ebay.com/itm/1-8-ZIF-CE-50pi ... 1401787863
If not, this may be able to help you: https://www.guidancesoftware.com/tablea ... e/tda5-zif
I forget whether the Hitachi or Toshiba ZIF cables would work with Samsung drives.
Hard Drive and RAID Data Recovery Specialist in Massachusetts
PostPosted: July 20th, 2017, 9:51
Thanks all of you for kind suggestions.
It looks that following Spildit's suggestion, I would need another mother board, which would be complicated for me (as a newbie). I am still studying what "HuaQue" and "labtech" suggested.
Thanks again!!!
Users browsing this forum: abolibibelot, Bing [Bot] and 33 guests
