 Post subject: HTS541010A9E680 compatibility
PostPosted: August 31st, 2017, 6:06
What drives are compatible with HTS541010A9E680 ?
Thank you
 Post subject: Re: HTS541010A9E680 compatibility
PostPosted: August 31st, 2017, 8:02
721010A9?
No bitcoin donations :)
PostPosted: August 31st, 2017, 10:13
will try, thanks Pepe
PostPosted: August 31st, 2017, 18:31
The subject HDD appears to use PCB # OA90351.
FWIW, my Google searches would suggest that the same PCB is used in the following models:
    HTS541010A9E680
    HTS541075A9E680
    HTS545050A7E680
    HTS545050A7E380
    HTS545032A7E380
    HTS725032A7E630
    HTS725050A7E630
    HTS721010A9E630
One question I would have is whether it is possible for 7200RPM and 5400RPM drives to use the same heads. ISTM that the heads would fly at different heights if this were the case.
PostPosted: August 31st, 2017, 21:52
thank you Frank
PostPosted: September 1st, 2017, 1:48
Wrong question - two answers:
compatible heads -> pepe
compatible PCB -> Fzabkar
PostPosted: September 1st, 2017, 3:50
somehow i thought you are looking for heads...
@Frank: I mixed heads in samsung SI/SJ back and forth, and many other families, including hitachies as well.
Since adapting FH is not a big problem for me i did not really care. Many times i have to do it even with heads from same family...
PostPosted: September 1st, 2017, 5:48
Sorry, should have said heads, pepe the 721010A9 is compatible Thanks :D
PostPosted: September 1st, 2017, 6:48
great! :)
Users browsing this forum: No registered users and 28 guests
