 Post subject: Donor matching for head WD swap process.
PostPosted: August 11th, 2017, 7:31
please check picture,
please who can tell me this donor HDD matching with Head damage HDD ?
 Post subject: Re: Donor matching for head WD swap process.
PostPosted: August 11th, 2017, 7:54
Looks good to me, but microjogs value would be better to know.
http://www.rescue-it.se
PostPosted: August 11th, 2017, 10:43
I would compare mod 02, or mod 47, or mod C5 if exist.....
PostPosted: August 11th, 2017, 13:06
Can't see why they weren't compatible....
No bitcoin donations :)
PostPosted: August 11th, 2017, 14:11
they should be good ...
Data Recovery Pakistan
PostPosted: August 11th, 2017, 15:48
Looks good for me :)
go ahead
http://www.alwasat4pc.com
PostPosted: August 14th, 2017, 1:44
hi,
here is the details from DonorDrives.com for matching WD.
Marvell (version 2)
These encompass most newer and modern Western Digital drives.
Use the following criteria to find a donor drive.
Model number: It is ideal to match the whole model number, but if none is available you can try one that matches the entire first part of the model number as well as these three characters in the second part: WD1200BEVT-22A23T0
Heads map: Match the physical heads (PH) map exactly. It is OK if the donor has more heads than the original drive, but all heads before that should match.
DCM: Locate the J or 2 in the DCM. It should be towards the end. Make sure that the J or 2 as well as the preceding character matches on the donor.
Preamplifier: Exact match for both vendor and revision.
Microjogs: Each value should be within 200 of the original drive — the closer the better.
Country of manufacture: Should be the same.
Date of manufacture: Should be within three months — the closer the better.
http://www.lifeguarddatarecovery.com
PostPosted: August 14th, 2017, 5:10
those are very strict rules imo...
PostPosted: August 14th, 2017, 7:43
Microjogs ,
That Too in The Fblite Series ,Why Not Show a Screenshot To Us ? . In Your Favourite Data Recovery Tool
@ Pepe Sir ,
You Are Correct To Strict Rules
PostPosted: August 14th, 2017, 8:35
And inaccurate. WD has more specfic rules depending on the family.
IMO that guide is strict and obsolete.
@OP: The drives should be compatible.
Northwind Data Recovery - Greece
WD Trusted Partners
PostPosted: August 15th, 2017, 14:17
Well,
You Remember Long Long Time Back i Had Sent You a PM Regarding Matching Heads in WDC HDDS ,I have Done Enough Research on This Subject Now And I Am Able To Nail More Then 95% Cases In 1 Shot ,1 Video i Did On This Recently -> https://www.facebook.com/amarbir.dhillo ... f=mentions
