 Post subject: Lenovo NAS ix4-300d
PostPosted: December 13th, 2017, 17:46
I have a Lenovo NAS in for the first time. Its set up as a RAID 5. All drives are the same size so I presume this is working on a standard RAID 5 setup. Drives are imaging at the moment. Two have physical issues but look recoverable. I see it has 'data protection' but looks like it failed to rebuild due to the two failed drives so at least one thing is in our favor.
If anyone has any experience of these units, are they a standard RAID 5 setup when all drives are the same size from new? Or are they a hybrid type of setup?
 Post subject: Re: Lenovo NAS ix4-300d
PostPosted: December 13th, 2017, 18:04
Nearly all NAS arrays will be a sort of RAID of partitions or LVMs. Usually each disk will have a OS partition which is a RAID 1 across all disks (that way any one disk can boot the NAS), then there will be a data partition which contains LVMs which are in a RAID.
Do yourself a favor and see if R-Explorer/UFSExplorer can just recognize the array once all drives and/or images are connected. Often it will for NASs.
PostPosted: December 13th, 2017, 18:11
Yep, will do and thanks. But but it was more a question about if the are like SHR or Drobo Beyond RAID as it has this 'data protection' feature.
PostPosted: December 14th, 2017, 6:23
SHR is still a combination of LVM and md-raid, as is X-RAID, just named in a fancy way. Drobo has its own specific format.
Users browsing this forum: Bing [Bot], Google [Bot], Krush206 and 23 guests
