Post new topic Reply to topic  [ 87 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: WDC AC31600H firmware issue ?
PostPosted: January 8th, 2018, 19:11
Ok ... The drive is TOASTED !!!
I did the Full Format with P-List and it ended up with error. When checking again the drive now is full of bad sectors. Same as with Format with P + G. I did restore the translator from backup but the user space is full of bad blocks. Time for testing and playing with the drive !!!
PostPosted: January 8th, 2018, 19:26
Interesting !!! I can't REMAP on this drive !!!! I can't place sectors on the G-List by erasing/Re-Maping using Victoria or even HDD/HRT !!!
The drive is not REMAPING at all by itself ....
Let's try with firmware tool.
PostPosted: January 9th, 2018, 2:59
Can you provide the Identify Device sector?
PostPosted: January 9th, 2018, 17:42
Here !!! Enjoy :)
Device ID output by ATA standard drive ID command :
ID.rar [965 Bytes]
Downloaded 129 times
ID "decoded" by HRT with "updated" ini file from here - viewtopic.php?f=1&t=35930&start=20
General configuration (bitmask)=0x427A
--  Format speed tolerance gap required=
--  Fixed device=
--  Head switch time > 15 us=
Number of removable cylinders=0
Number of heads (default)=16
Number of sectors per track (default)=63
Number of bytes of Sector Gap=16
Number of bytes in Sync Field=0
Number of Sectors per Card (CFA ONLY)=16
Serial number=WD-WT2890563158
Controller Type=3
Buffer size (x512 bytes)=256
R/W Long ECC Bytes=22
Firmware Revision=17.11P19
Model Number=WDC AC31600H
Multiple sectors per DRQ interrupt=16
Trusted Computing (TCG) supported=No
IORDY is supported=Yes
IORDY can be disabled=Yes
LBA supported=Yes
DMA supported=Yes
BLOCK ERASE EXT command supported=No
OVERWRITE EXT command supported=No
CRYPTO SCRAMBLE EXT command supported=No
SANITIZE feature set supported=No
Multiple sector setting valid=Yes
Current Multiple sector setting=0
Total User LBA=3173184
Multiword DMA mode 2 is=not selected
Multiword DMA mode 1 is=not selected
Multiword DMA mode 0 is=not selected
Multiword DMA mode 2 and below are supported=Yes
Multiword DMA mode 1 and below are supported=Yes
Multiword DMA mode 0 and below are supported=Yes
PIO modes supported=3
Minimum multiword DMA transfer cycle time (ns) per word=120
Manufacturer_s recommended multiword DMA cycle time (ns)=120
Manufacturer_s PIO cycle time (ns) without flow control=160
Manufacturer_s PIO cycle time (ns) with flow control=120
CFast Specification Supported=No
Deterministic Read after TRIM is Supported=No
Long Physical Sector Alignment Error Reporting Control is Supported=No
DEVICE CONFIGURATION IDENTIFY/SET DMA Supported=No
Read Buffer DMA Supported=No
Write Buffer DMA Supported=No
SetMax DMA Password/Unlock Supported=No
Download Microcode DMA Supported=No
IEEE-1667 xxxx Supported=No
Optional ATA 28-bit commands Supported=No
Read Zero after TRIM Supported=No
** Device Encrypts All User Data=No
Extended Number of User Addressable Sectors Supported=No
All Write Cache Non-Volatile=No
Max Queue Deptn (n-1)=0
Read Log DMA Ext as Read Log Ext Support=No
Device Automatic Partial to Slumber Transitions Support=No
Host Automatic Partial to Slumber Transitions Support=No
SATA Supports NCQ priority information=No
SATA Supports Unload while NCQ commands are outstanding=No
SATA Supports PHY Event Counters=No
SATA Supports IPM Requests=No
SATA Supports NCQ=No
SATA Supports GEN4 12.0Gbps=No
SATA Supports GEN3 6.0Gbps=No
SATA Supports GEN2 3.0Gbps=No
SATA Supports GEN1 1.5Gbps=No
DEVSLP to Reduced Power State=No
Receive FDPDMA Queued and Send FDPDMA Queued Commands Supported=No
SATA Supports NCQ Queue Management Supported=No
SATA Supports NCQ Streaming=No
SATA Link at GEN3 6.0Gbps=No
SATA Link at GEN2 3.0Gbps=No
SATA Link at GEN1 1.5Gbps=No
Power Disable Supported=No
Rebuild Assist Supported=No
Device Initiated IPM Software Settings Supported=No
Hybrid Information Feature Supported=No
Link Power State Device Sleep Supported=No
NCQ Autosense Supported=No
SATA Supports Software Settings Preservation=No
SATA Hardware Feature Control (MICRON SSDs)=No
SATA Supports in-order data delivery=No
SATA Supports Initiating Power Management=No
SATA Supports DMA Setup auto-activation=No
SATA Supports non-zero buffer offsets in DMA Setup FIS=No
Rebuild Assist Enabled=No
Power Disable Enabled=No
Hybrid Information Feature Enabled=No
Device Sleep Enabled=No
Device Automatic Partial to Slumber transitions Enabled=No
SATA Software Settings Preservation Enabled=No
SATA Asynchronous notification Enabled=No
SATA In-order data delivery Enabled=No
SATA Initiating Power Management Enabled=No
SATA DMA Setup auto-activation Enabled=No
SATA non-zero buffer offsets in DMA Setup FIS Enabled=No
ATA9/ACS-4=No
ATA9/ACS-3=No
ATA9/ACS-2=No
ATA8-ACS=No
ATA/ATAPI-7=No
ATA/ATAPI-6=No
ATA/ATAPI-5=No
ATA/ATAPI-4=No
ATA/ATAPI-3=No
ATA/ATAPI-2=No
ATA/ATAPI-1=No
Minor Revision Number=0x0
NOP supported=No
READ BUFFER supported=No
WRITE BUFFER supported=No
HPA supported=No
DEVICE RESET supported=No
SERVICE interrupt supported=No
RELEASE interrupt supported=No
READ-LOOK AHEAD supported=No
Volatile WRITE CACHE supported=No
PACKET Command supported=No
Power management supported=No
Removable supported=No
Security supported=No
SMART supported=No
FLUSH CACHE EXT Supported=No
FLUSH CACHE Supported=No
DCO Supported=No
48-bit Address Supported=No
AAM Supported=No
SET MAX security extension Supported=No
SET FEATURES subcommand required to spinup after power-up=No
PUIS Supported=No
Removable Media Status Notification feature Supported=No
APM Supported=No
CFA Supported=No
READ/WRITE DMA QUEUED (TCQ) Supported=No
DOWNLOAD MICROCODE Supported=No
IDLE IMMEDIATE with UNLOAD FEATURE Supported=No
AV Lite Read/Write Cache Supported=No
AV Lite Feature Supported=No
URG bit Supported for WRITE STREAM (DMA) EXT=No
URG bit Supported for READ STREAM (DMA) EXT=No
64-bit WWN Supported=No
WRITE DMA QUEUED FUA EXT Supported=No
WRITE DMA/MULTIPLE FUA EXT Supported=No
GPL Supported=No
Streaming Supported=No
Media Card Pass Through Command Supported=No
Media Serial Number Supported=No
SMART Self-test Supported=No
SMART Error Logging Supported=No
NOP Enabled=No
READ BUFFER Enabled=No
WRITE BUFFER Enabled=No
HPA Enabled=No
DEVICE RESET Enabled=No
SERVICE interrupt Enabled=No
RELEASE interrupt Enabled=No
READ-LOOK AHEAD Enabled=No
Volatile WRITE CACHE Enabled=No
PACKET Command Enabled=No
Removable Enabled=No
Security Enabled=No
SMART Enabled=No
FLUSH CACHE EXT supported=No
FLUSH CACHE supported=No
DCO supported=No
48-bit Address supported=No
AAM enabled=No
SET MAX security extension enabled by SET MAX SET PASSWORD=No
(Reserved - project 1407DT Address Offset Reserved Area Boot)=No
SET FEATURES subcommand required to spin-up after power-up=No
PUIS enabled=No
Removable Media Status Notification enabled=No
APM enabled=No
CFA enabled=No
READ/WRITE DMA QUEUED supported=No
DOWNLOAD MICROCODE supported=No
IDLE IMMEDIATE with UNLOAD FEATURE Enabled=No
AV Lite Read/Write Cache Enabled=No
AV Lite Feature Enabled=No
URG bit Enabled for WRITE STREAM (DMA) EXT=No
URG bit Enabled for READ STREAM (DMA) EXT=No
64-bit WWN Enabled=No
WRITE DMA QUEUED FUA EXT Enabled=No
WRITE DMA/MULTIPLE FUA EXT Enabled=No
GPL Enabled=No
Streaming Enabled=No
Media Card Pass Through Command Enabled=No
Media Serial Number valid=No
SMART Self-test Enabled=No
SMART Error Logging Enabled=No
UDMA-7 is Selected (?)=No
UDMA-6 is Selected=No
UDMA-5 is Selected=No
UDMA-4 is Selected=No
UDMA-3 is Selected=No
UDMA-2 is Selected=No
UDMA-1 is Selected=No
UDMA-0 is Selected=No
UDMA-7 and below are Supported (?)=No
UDMA-6 and below are Supported=No
UDMA-5 and below are Supported=No
UDMA-4 and below are Supported=No
UDMA-3 and below are Supported=No
UDMA-2 and below are Supported=No
UDMA-1 and below are Supported=No
UDMA-0 is Supported=No
Time required for Security Erase completion=0
Time required for Enhanced Security Erase completion=0
Current APM value=0x0
Master Password Identifier=0x0
Hardware Reset Result=0x0
Vendor's recommended AAM value=0x0
Current AAM value=0x0
Stream Minimum Request Size=0
Streaming Transfer Time - DMA=0
Streaming Access Latency - DMA and PIO=0
Streaming Transfer Time - PIO=0
Max number of 512b blocks of LBA Range Entries per DATA SET MANAGEMENT command=0
Advanced Format Feature supported=No
* Device has multiple Logical Sectors per Physical Sector=No
* Device Logical Sector Longer than 256 Words=No
* 2^X Logical Sectors per Physical Sector=0
Inter-seek delay for ISO-7779 acoustic testing in microseconds=0
* Words per Logical Sector=0
Device Statistics Notification (DSN) Feature Supported=No
Accessible Max Address Configuration Feature Supported=No
Extended Power Conditions feature set Supported=No
Extended Status Reporting feature set Supported=No
Free-Fall Control Supported=No
The Segmented feature for DOWNLOAD MICROCODE Supported=No
READ/WRITE LOG DMA EXT optional commands Supported=No
WRITE UNCORRECTABLE EXT Supported=No
Write-Read-Verify Feature Set Supported=No
Device Statistics Notification (DSN) Feature Enabled=No
Accessible Max Address Configuration Feature Enabled=No
Extended Power Conditions feature set Enabled=No
Extended Status Reporting feature set Enabled=No
Free-Fall Control Enabled=No
The Segmented feature for DOWNLOAD MICROCODE Enabled=No
READ and WRITE DMA EXT GPL optional commands Enabled=No
WRITE UNCORRECTABLE EXT Enabled=No
Write-Read-Verify Feature Set Enabled=No
Security Enhanced Erase supported=No
Security Count Expired=No
Security Frozen=No
Security Locked=No
Security Enabled=No
Security Supported=No
MICRON SSD: FW_Version-like=
MICRON SSD: unknown ASCII #1=
MICRON SSD: unknown ASCII #2=
DEBUG (Samsung) 2^X Logical Sectors per Physical Sector=0
** Minimum Standby timer value=0
** Automatic Standby timer value=0
CFA Power Mode Supported=No
CFA Power Mode 1 required for one+ commands=No
CFA Power Mode 1 Disabled=No
CFA Power Mode max current (mA)=0
CFA Key Management Schemes Supported=0x0
--  Device supports CPRM Scheme=No
CFA TrueIDE Timing Mode Capabilities and Settings=0x0
CFA PCMCIA I/O and Memory Timing Modes Capabilities and Settings=0x0
Device nominal form factor=0
DATA SET MANAGEMENT - TRIM is supported=No
Current Media Serial Number=
SCT Data Tables supported=No
SCT Features Control supported=No
SCT Error Recovery Control supported=No
SCT Write Same supported=No
SCT Long Sector Access supported=No
SCT Supported=No
Alignment of logical blocks within a larger physical block=No
Logical sector offset within the first physical sector where the first logical sector is placed=0
Write-Read-Verify Sector Count Mode 3 Only=0
Write-Read-Verify Sector Count Mode 2 Only=0
NV Cache feature set version=0x0
NV Cache Power Mode feature set version=0x0
NV Cache feature set enabled=No
NV Cache Power Mode feature set enabled=No
NV Cache Power Mode feature set supported=No
NV Cache Size in Logical Blocks=0
Nominal RPM=0
Write-Read-Verify feature set current mode=0
Transport Type - PATA=
Transport Major revision - SATA Rev 3.2=No
Transport Major revision - SATA Rev 3.1=No
Transport Major revision - SATA Rev 3.0=No
Transport Major revision - SATA Rev 2.6=No
Transport Major revision - SATA Rev 2.5=No
Transport Major revision - SATA II: Extensions=No
Transport Major revision - SATA 1.0a=No
Transport Major revision - ATA8-APT/AST=No
Transport Minor revision=0x0
Minimum 512B units per DOWNLOAD MICROCODE mode 03h=0
Maximum 512B units per DOWNLOAD MICROCODE mode 03h=0
PostPosted: January 9th, 2018, 18:03
Drive is really messed up.
I can WRITE to all sectors but when the drive writes to BAD sectors it will write fine and will not report any error. When reading the data on those damaged sectors will be currupted and verify will report error but sectors are NOT added to the G-List. I did try full erase, zero fill, even using HRT option to write random pattern, etc ... all sectors write ok with exception of bad ones that are not re-mapped. Tested with Victoria with Remap on and write on, etc .... nothing apears to re-map the sectors. So .... I did tought about Self-Scan but HDD.exe doesn't have SS option for those "old" generations of WDC MCU based. For MCU based on WDC (Not MARVELL) HDD48.exe allows to Self Scan but only on x_A, and x_B models !!!
I did test the x_A utility because some commands like the super format, etc are the same but ..... it doesn't work !!!
Looks like it requires some modules that my drive doesn't have like C4 and C5. I can make the script by HRT but it won't work on this "older" drive.
Also i do have a start command fo SS "old" drives but doesn't do a thing on my drive ...
I will try to edit modules ..... I will try to change the drive ID from the correct model to something like Spildit.
PostPosted: January 9th, 2018, 18:13
Ok ... I did mess up a little bit .... I did end up "patching" the SERIAL instead of the model lololol
But it works !!!!
Goes without saying i can write to SA without any problem as well !
PostPosted: January 9th, 2018, 18:32
FWIW, ISTM that Identify Device words 04 and 05 define the format of the SA tracks.
    Word 04 = bytes per track = 0xE100
    Word 05 = bytes per sector = 0x258
    Sectors per track = 0xE100 / 0x258 = 0x60 (96)
Offset(d) 00   01   02   03   04   05   06   07   08   09
00000000  7A42 4C0C 0000 1000 00E1 5802 3F00 1000 0000 0E00  zBL......áX.?.......
00000010  4457 572D 3254 3938 3530 3336 3531 2038 2020 2020  DWW-2T98503651 8
00000020  0300 0001 1600 3731 312E 5031 3931 4457 2043 4341  ......711.P191DW CCA
00000030  3133 3036 4830 2020 2020 2020 2020 2020 2020 2020  1306H0
00000040  2020 2020 2020 2020 2020 2020 2020 1080 0000 002F                .€.../
00000050  0000 8003 0000 0200 0000 0000 0000 0000 0000 0001  ..€.................
00000060  406B 3000 0000 0704 0300 7800 7800 A000 7800 0000  @k0.......x.x. .x...
00000070  0000 0000 0000 0000 0000 0000 0000 0000 0000 0000  ....................
00000250  0000 0000 0000 0000 0000 782D                      ..........x-
PostPosted: January 9th, 2018, 18:48
I don't think so .....
If i do a read on SA tracks i only start to get errors at :
Read error on Cyl=-1, h=all, s=151 -
Also there are data up untill SPT 128 - offset FFF0
PostPosted: January 9th, 2018, 18:51
Track -5 have info up untill 121f0 so SPT is higher ....
PostPosted: January 9th, 2018, 18:57
I think SPT on my drive (firmware) is 150.
PostPosted: January 9th, 2018, 18:59
Oops, I confused myself. AISI, the "BAD" stuff begins at offset 0x12C00, so the SPT for the SA is 0x12C00 / 0x200 = 0x96 (150).
PostPosted: January 9th, 2018, 19:11
Is there any chance you could add hires photos/scans of the PCB to your HDD Oracle database? I'm curious to see how your WD MCU differs from later ones.
PostPosted: January 9th, 2018, 19:13
AGREE !!!! Because i can read up untill that without error on HDD. :D
PostPosted: January 9th, 2018, 19:14
Yes. I will take a photo and post later. No problem !
PostPosted: January 10th, 2018, 4:54
FWIW, some old Seagate models allow the user to enable/disable "all automatic defect assignment" via the Set Features EFh (04h/84h) command.
PostPosted: January 10th, 2018, 17:22
Doesn't work on my WD ....
PostPosted: January 10th, 2018, 17:34
Old HRT prototype HDD.exe does have many options that were removed from retail HRT product. Not only HRT doesn't support those old WD (that HDD.exe supports) but also ALL Self-Scan options were removed from retail HRT while they are present on the prototype.
I did find a interesting option on the HRT prototype as well :
Old WD ZONE issuer. If one uses the "Issue HDD" option it somehow "brite forces" the zones and SPT ... It takes a minute or so while it's filling the zone table so it's somehow re-creating it by reading drive.
Firmware have cyl -1 to -5 (starts at -5) and SPT of 150.
Yesterday i did discover the SPT for Zone 1 (User area first track) by brute force and discover the same value - 171. I did this by "hand this way :
Service - I/O Operations :
Physical READ with HEAD 0
Track 0 to Track 0
SPT for example - 200
One would start to get errors at sector 172 so sector 171 is the last one that can be read for that track :
It reads the entire track consecutively without switching heads so LBA 0 to 170 goes on the same track and does make the 171 SPT for each track at the start of the drive - first user area zone.
PostPosted: January 10th, 2018, 18:04
Can you upload your zone table? I think I may have misidentified it in a previous post.
BTW, I have analysed the bad sectors in your previous screen shot.
LBA      diff    track count + skew?
23611   + 2011 = (11 x 171) + 130
25622   +  130 =            + 130
25752   + 1840 = (10 x 171) + 130
27592   +  130 =            + 130
27722   + 2011 = (11 x 171) + 130
29733   +  130 =            + 130
29863   + 1840 = (10 x 171) + 130
31703
I'm not sure what to make of it.
PostPosted: January 10th, 2018, 18:13
Here :
max cyl=4045
zones=17
Firmware=-5 -1 150
zone0=-5 150
zone1=0 171
zone2=270 168
zone3=375 164
zone4=545 160
zone5=769 155
zone6=1110 150
zone7=1401 141
zone8=1726 133
zone9=2104 126
zone10=2345 120
zone11=2629 114
zone12=2859 110
zone13=3272 104
zone14=3498 100
zone15=3707 94
zone16=3888 89
Users browsing this forum: Bing [Bot] and 26 guests
