 Post subject: PCB swap on a WD10EAVS
PostPosted: January 9th, 2018, 4:21
I replied to an anoucement on a classified ads website from someone looking for a Western Digital WD10EAVS, so as to recover data from his non-functional unit by attempting a PCB swap. I happen to have a unit of that model, so I could sell it to him (he's in another town, no way to make a quick try beforehand). He is sure that the issue comes from a defective PCB : the HDD doesn't start at all with its native PCB, he tried to swap it with that of a 500GB model, and it did start then, although of course it didn't work properly.
But I've read repeatedly that on most modern HDDs it's not possible to swap the PCB and have it work right away : even if it's a compatible model, there's a chip containing specific calibration data and whatnot (what else exactly ?) only relevant to one particular unit that needs to be unsoldered from the defective PCB and resoldered to the replacement PCB. Is this the case with that particular model ? If so, what exact chip is it ? Is it relatively easy to do with a common soldering iron, or very tricky and requiring specialized tools / experience ? (He seems to be sure that it'll be easy as a pie, but any reasonable grandma would tell ya that a pie ain't that easy ! :))
Then, he says that his HDD's exact model is “WD10EAVS-32D7B1” and the PCB has the code “2061-701590-A00AE. Mine is a “WD10EAVS-00D7B1” and the number on the board is “2060-701590-000 REV A” ; there's also a small label with this code : “2061 - 701590 - A00 AD XW 7C20 4FK2 6 0001380 9381”. Would it be compatible ?
That HDD (mine) is 100% functional, and currently full, so as much as I'd be willing to help the guy, I don't want to go through that hassle if there's zero chance that it will work.
Thanks !
“Grandparents in Hell !... Picture that – picture your grandmother in Hell : baking pies... without an oven...”
George Carlin
 Post subject: Re: PCB swap on a WD10EAVS
PostPosted: January 9th, 2018, 4:32
Some MCUs have internal flash memory. Others have an external serial flash chip at U12. Is your U12 location populated?
Analysis of the "ROM" on a Western Digital ROYL HDD:
http://www.hddoracle.com/viewtopic.php?f=59&t=225
PostPosted: January 9th, 2018, 4:57
Well, what is a MCU ? And what do you mean by U12, is this a code on the PCB ? Let's have a look... I see many E something, a few P something and TV someting, but no U something, if that's what you mean (I haven't unscrewed it to look at the other side). And I couldn't give you more info for that defective HDD which is not mine. Are there that many differences on HDDs sharing the same model number ?
Also, could it be fixable by removing a damaged diode, as I saw in some threads here, including this recent one ?
PostPosted: January 9th, 2018, 5:36
Here is a pic of 701590-001. You need to unscrew your pcb and check the other side.
Mcu is the processor...big chip with an M.
http://www.rescue-it.se
PostPosted: January 9th, 2018, 6:29
Alright. But what would it entail if there is or is not a ROM in U12 on my PCB ?
And can the owner of the defective HDD attempt something with those diods ?
Thanks for the quick reply !
PostPosted: January 9th, 2018, 6:40
Could You post a picture of the electronic board?
If You do not have external Rom than the rom is located in MCU.
It is possible to recover this rom with PC3000 or rebuild it from SA (using pc3000). Also You can resolder MCU if You have skils :-) Or repair the oryginal electronic board.
Backup is Your best friend. Still learning English. Sorry for language bugs. My website
PostPosted: January 9th, 2018, 13:24
Your drive belongs to "Kermit" family. All drives of this family have an external ROM chip ( U12). You have two options:
1. To swap the ROM chips by desoldering / resoldering
2. To transfer the ROM content from one PCB to the other by using a program like WDMarvel, WDR, etc.
PostPosted: January 9th, 2018, 13:54
HDD from Inside: Hard Drive Main Parts:
http://hddscan.com/doc/HDD_from_inside.html
PostPosted: January 9th, 2018, 14:16
This one has no ROM at U12:
https://www.harddrivesforsale.com/it/wd10eavs-00d7b1-pcb-2061-701590.html
https://www.harddrivesforsale.com/media/catalog/product/cache/3/image/560x800/b61f6e664c77c06cd32013c973526a8f/2/3/23842a.jpg
PostPosted: January 9th, 2018, 15:40
If the drive has ROM chip swap it to the good board...if it doesn't have, swap both diods with the ones from the good board....you can measure them to find the faulty one if know how...or swap both.
PostPosted: January 9th, 2018, 16:02
Option 3 - External ROM programmer !!!
If you use SOIC8 clip you don't have to solder/unsolder :
http://www.hddoracle.com/viewtopic.php?f=117&t=865
If the original PCB is gone / damaged you most likely can't read the ROM on it with firmware tools. If PCB have external ROM chip then there will be no copy of ROM modules on SA. It's not "viable" to read the ROM with exception of some cases that you might get luck to read ROM by TTL ... But if you have external chip + external programmer (cheap) then problem solved ...
PostPosted: January 9th, 2018, 16:06
The problem is NOT if you have or not a ROM chip on your PCB. The problem is that if the damaged drive have or have not a ROM chip.
If the damaged drive doesn't have a ROM chip (external) most likely it will have a copy of the ROM modules on SA. You can place your PCB there and you will gain access to SA with tools like WDMarvel, SeDiv, PC-3000, HRT, whatever and you will read SA and from those modules you re-build ROM (original). Then you write that to your PCB and you are good to go and you will have user area access, assuming the problem is just with the PCB.
If you have a short diode (TVS) then if you plug the drive to a PSU the PSU will shut down, meaning that on internal PC drives with shorted TVS the system will not even power on. If your system is running fine with the drive plugged to it (to the internal PSU) then most likely the problem is not related to shorted TVS.
PostPosted: January 9th, 2018, 16:10
This might be a waste of time. If the damaged drive have ROM chip swap it to the good board, or read the content with external programmer, etc .... If the drive doesn't have ROM chip don't swap diodes without making sure that they are shorted. Also if you have a known good PSU you can just remove the TVS/Diodes and run the drive without them, no need to be removing TVS from the known good PCB.
MAKE SURE THAT BOTH PCBs HAVE ROM CHIP.
If damaged PCB have ROM chip (external) and your PCB doesn't have ROM chip (internal masked on MCU) if you swap the ROM chip from the damaged drive to your PCB your PCB will still read ROM from MCU (internal) and will NOT read the contents of the ROM chip unless you mess up with some resistors as well ....
PostPosted: January 9th, 2018, 22:41
@COD
I can send a picture of my electronic board, but what would be relevant would be a picture of the defective one, right ?
I could ask the owner of the defective HDD to send a picture, and post it, but that would become too time-consuming to help solve an issue for a total stranger with no reward for it.
I don't have access PC3000, and surely neither does the owner of the defective unit.
Repair the original board : how exactly ? Replacing a diod / fuse ? How to methodically identify the defective component(s) ?
@BGMan & fzabkar
Well, those are contradictory informations...
But again, the defective one is WD10EAVS-32D7B1, not WD10EAVS-00D7B1 which is my (functional) HDD and could be a potential donor.
Does it change the answer to that question ?
EDIT : Answering my own question, WD10EAVS-32D7B1 PCB has no ROM chip in U12 either :
https://www.harddrivesforsale.com/it/wd ... 00-ad.html
@Spildit
Alright, I got that part by myself, hence my questioning! :)
What do you mean by “place your PCB there” ? Maybe you mean place the PCB from my (functional) WD10EAVS onto the defective one ?
Again, the owner very probably won't have access to the kind of pro tools you mentioned. He expects this to be a straightforward, plug-and-play procedure. I warned him that it might not be that simple.
How can anything be written to the PCB, if there is no ROM chip ?
And if there's a copy of the ROM modules on the SA, but no ROM chip, then where is the other copy ?
Alright, that's definitely a useful piece of information.
So if it is not a short diode, it's necessarily a system area issue ?
PostPosted: January 10th, 2018, 1:17
No. The first two characters of the model number suffix represent a customer ID.
According to the following document, "the model number suffix (characters to the right of the dash following the model number) is only for in-house use. Refer to Change Administration’s Model Specification (document number 2096-000101)."
Model Number Format for OEM and Distribution Channels:
http://www.wdc.com/wdproducts/library/F ... 001028.pdf
I haven't seen WD's internal document, but here is an explanation in Russian:
http://www.acelab.ru/dep.pc/doc.pc3000d ... in-N-2.pdf
Here is Google's English translation:
http://translate.google.com/translate?h ... in-N-2.pdf
TVS Diode FAQ :
Catastrophic failures in Western Digital PCBs:
http://www.hddoracle.com/viewtopic.php?f=100&t=2169
WD's TVS diodes (photo):
http://www.hddoracle.com/download/file. ... &mode=view
newbie info, from and for newbies :) About firmware ...
viewtopic.php?t=6562
PostPosted: January 10th, 2018, 16:12
- By place your PCB there i mean place the working PCB on the drive you want to recover.
- If there is no ROM chip there will be ROM flash space embeded on the MCU and you can write the code there. The Vendor Specific Commands to access that space are the same ones used to access the external ROM chip. The drive knows if it have to read from ROM chip (external) or embeded ROM on MCU by resistor setting on PCB.
- The copy (backup) will be on SA and the working ROM is embeded on the MCU (inside the MCU).
- If the drive doesn't spin at all with the defective PCB there might be other issues like for example a shorted pre-amp inside the drive. A shorted pre-amp will make the drive not to spin. Just because it doesn't spin it's not necessarly a PCB issue. Also if ROM code is damaged drive will not spin. If drive have SA/Firmware issues then it have to SPIN. Because SA is written on platter .... So if it doesn't spin at all it will not read SA at all .... For example imagine a bad S.M.A.R.T. module on SA causing problems. If the drive can't spin at all it will not load that model to start with. Only if the drive is spinning the module can be read and if it's damaged will cause a problem ... The problem is way prior to any SA code on the platter to be loaded ....
PostPosted: January 10th, 2018, 19:48
Maybe we are all answering as if @abolibibelot had both disks with him.
@abolibibelot, if you are just selling the disk to a total stranger, as you commented :
- you can not sell it, if it is ok, and sell it to someone that needs a good disk.
- you can sell it, tell the person that you believe it won´t work, and don´t worry anymore. The problem is of the person that insists in buying the disk.
- you can tell the person to send you his hdd, so that you can try to fix it for him ( for a price, obviously )
PostPosted: January 11th, 2018, 5:55
@rogfanther
Thanks for summing up what my options are ! :)
I created this thread in part to gather some practical knowledge for myself, having no experience yet with a similar case. (I've never attempted a PCB swap.) Indeed I could have chosen option B, sell it and move on, regardless of the possible outcome, but that would be a waste of a perfectly good HDD if it turns out that it couldn't work for specific reasons (well, actually no : that person said that if the swap doesn't work the one I have could still serve as a backup). That person seems decided to deal with the issue him/herself, so option C is probably not an option... I had not yet decided to sell that one in particular, but I have way too many HDDs, I'm expecting to receive two 8TB units in a few days (WD80EFZX), so I'll surely sell quite a few of the others, might as well sell that one to someone who specifically needs this model, if it is indeed a realistic endeavour to attempt that kind of DIY fix.
@Spildit
From what I could gather in the replies I got above, and the links provided, both units do not have an external ROM chip in U12, so, according to what you say here, they must have ROM code embedded in MCU. In short, does that mean that the PCB swap can not work without issuing vendor specific commands ? Would it be wiser for that person to first try to test those diods and remove the potentially shorted ones ? (I provided a link to this thread to the owner of the defective unit, so even if I'm begining to understand some intricacies of such cases, I'm trying to elicit straightforward answers that a person operating at an even lower (!) knowledge level can comprehend... :) )
If the drive doesn't spin at all with the defective PCB there might be other issues like for example a shorted pre-amp inside the drive. A shorted pre-amp will make the drive not to spin. Just because it doesn't spin it's not necessarly a PCB issue. Also if ROM code is damaged drive will not spin. If drive have SA/Firmware issues then it have to SPIN. Because SA is written on platter .... So if it doesn't spin at all it will not read SA at all .... For example imagine a bad S.M.A.R.T. module on SA causing problems. If the drive can't spin at all it will not load that model to start with. Only if the drive is spinning the module can be read and if it's damaged will cause a problem ... The problem is way prior to any SA code on the platter to be loaded....
The owner of the defective drive said that swapping the PCB with that of a 500GB unit was enough to have it start up again (albeit not enough to access the data, obviously). So that would rule out a pre-amp failure, right ? Otherwise, I don't know the likely (external) cause of failure.
Again, hasn't it been established above that both WD10EAVS do not have an external ROM chip in U12 ?
Regardless, what do you mean here by external programmer, and what has to be programmed exactly ? Even if it's cheap it seems way too technical for the average Joe or Jane ! :) Myself, I would dearly try something like that, but again, this person expects this to be merely a plug-and-play procedure, and apparently I was right in suspecting that it would actually be more complicated than that... I'm trying to evaluate the level of that complexity, for something that I most likely won't do myself (on this occasion anyway).
Thanks again.
PostPosted: January 12th, 2018, 11:04
The drives have the rom content either in an external ROM chip, or inside the MCU.
When there is an external ROM chip, it can be swapped from the bad board to the good one.
If the ROM is inside the main MCU, then it has to be copied ( WDR, WdMarvel, HDDSupertool, PC3000, etc ) from the bad board to the good one. Yes, this is done by the software using VSCs. Other ways may exist, but they are more complex and cost more.
Not a thing so easy to your possible customer to do on his own, because if he destroys the chip or other important component in the board, then recovery will be much more difficult and costly.
About the external programmer there is some information here :
http://www.hddoracle.com/viewtopic.php?f=110&t=1738
PostPosted: January 12th, 2018, 15:51
- The damaged PCB and your PCB might or might not have the external chip. You have to check that out on the PCB. even if they have the same model and PCB version there are the chance that one have external ROM and the other have internal one. The only way to be sure is to check.
- Only if you are extremely lucky will the PCBs work without swapping the ROM chip or write the native ROM code on the new PCB as there will be adaptives on ROM modules.
- Owner can check TVS/DIODES but if the drive is not shorting the PSU and shutting the system down then it will have other issues like open resistor and there will be no short-circuit.
- Pre-amp might still be damaged or heads might still be damaged even if the drive spins with a non-native PCB. What we can assume is that the pre-amp at least is not shorted otherwise it would not make the drive spin.
- Does the drive clicks ? Does the drive makes a noise of heads reading something ?
- External programmer would be used if the drives have external ROM chip to copy the content of the ROM chip from one chip to the other. If you use SOIC 8 CLIP you don't have to de-solder and re-solder ROM chips :
- If the ROM is inside MCU there will exist a copy of the ROM on SA (platter) so one would replace the PCB with compatible one and use some sort of WD firmware tool to read ROM copy from SA and write it to PCB.
Users browsing this forum: Bing [Bot], MasterT and 19 guests
