 Post subject: Seagate ST380811AS doesn't show up over ATA
PostPosted: January 27th, 2018, 22:10
Im not 100% on what happened here, so i'll just lay it out.
This 7200.9 was used in a contest to see who could recover data from a drive that was zero'd and had badblocks run on it. Safe to say, nothing was recovered. There was an attempt made to dump the individual sectors over the serial UART for analysis and in doing so it disappeared from the ATA bus. Im out of my league to be honest here, it's not a Linux/Unix or VxWorks powered embedded machine. So far ive cleared SMART, cleared the glist. and that's as far as i got. still doesn't show up. Here is the output of the, eh, POST(?)
 Post subject: Re: Seagate ST380811AS doesn't show up over ATA
PostPosted: January 28th, 2018, 6:21
Wow ,
Data Recovery From a ZERO Filled Drive .So If Data Does Not Come out Of SATA/IDE Ports We Will Sniff It Out From Serial Port Lol Seriously .Man Is This a Joke
PostPosted: January 28th, 2018, 8:35
Well if it is a 80GB drive, old, and used in a contest to prove or disprove something, where a couple of people will have done many things to the drive, it is hard to know what may have happened to it.
You could maybe try to "rebuild" it, running some kind of selfscan and restoring the backup of SA that you surely made before the testing.
Other than that, just bin the drive and get another one to continue with the experiences, this size of drives is cheap in ebay/craigslist.
PostPosted: January 28th, 2018, 9:30
Plug the drive to the TTL adaptor and post the log !
Most lilkely "something" was deleted from the SA tracks like the ATA overlay.
On those ST-10 drives it should still be possible to "fix" the damage (with expensive firmware tools) as long as the heads, pre-amp and platter surface are still in a good condition ....
How did you clear S.M.A.R.T. and G-List ? By terminal commands ? What commands did you use ? Hopefully commands for ST-10 instead of F3 ARCH. N commands will start Self-Scan on those and will erase firmware on the drive as well ... If you use N2 and CTRL+T and you stop the test while it's clearing SA you will be in for pain !!!
Does the drive clicks or makes any abnormal sound ? If you are lucky to be just SA related it can still be fixed but most likely not by you ....
Users browsing this forum: PA3040 and 11 guests
