Post new topic Reply to topic  [ 53 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Toshiba Clear G-list ATA command
PostPosted: March 30th, 2018, 12:20
Can you WRITE to the drive with PC3K ?
Maybe PC3K is turning on read look ahead by default when you run the drive on it ? If you use Victoria and you set the cache ON there does it READ at proper speed ?
PostPosted: April 1st, 2018, 19:39
Hi
With Pc3k only the Physical Test run with full speed.
Normal Verify is like Read look ahead.
If i use Enable Read look Ahead in RAM, no effect on the hard disk.
I also discus with My teacher, he also thinking for finding Modules, because there is no header in the start on Toshiba CP, its very difficult to find Modules in Toshiba.
I mean Exact modules, until VSC command and documentations.
till now, i have unlocked the hard disk, but have issue with Read look ahead, and writing test not start showing ERR Lights on all Sectors.
I thought that there might be some lock in the Firmware Area, and that area also available in the ROM part,
Like half adaptive in Firmware SEction and some part in Platers and some in ROm.
When all get compatiable hdd start work properly.
do you have any Vender command to unlock password by Pc3k ATA shell ?
I am trying to finish my New Lab, and then i share ROM , i think take 1 or 2 more days
Kind Regards
PostPosted: April 2nd, 2018, 14:07
Yes, but only to unlock ATA password and it's the SAME command that SeDiv Does use as i did "sniff" those commands out of SeDiv.
PostPosted: April 18th, 2018, 19:43
Hi
Here is the Original ROM.
320GB 55 VCT locked.zip [310.89 KiB]
Downloaded 132 times
Here is the Donor ROM ROM.
oRIGINAL rom v sERIES.zip [308.04 KiB]
Downloaded 113 times
here is the ROM which i manually make to get access of FW area.
Just copy all CP from patient to donor, and write to HDD,
i got access to FW area.
320GB 55 VCT unlocked.zip [308.17 KiB]
Downloaded 118 times
Kind Regards
PostPosted: April 19th, 2018, 19:06
[quote="waqas_ali766"]Hi
who is the teacher of WAQAS ALI,
PostPosted: April 20th, 2018, 15:21
RAJOO wrote:
(...)I also discus with My teacher,
Cool ! And ... ?
PostPosted: September 22nd, 2018, 23:57
Has there been any progress with the write problem? I have a potentially simple solution, but I'd like to see a full track dump of both patient (locked) and donor (unlocked).
PostPosted: October 1st, 2018, 18:51
Looks interesting ....
PostPosted: October 1st, 2018, 19:01
I'm wondering if the locked drive uses the same security module (S) on track #2 (?). If not, and if this module is not present in the locked SA, then the unlocked ROM code might be dropping back to read-only mode. My proposed solution would be to write an unlocked S module to the SA.
See http://www.hddoracle.com/viewtopic.php?f=23&t=2552&start=20
PostPosted: October 2nd, 2018, 9:43
Toshiba VS doesn't have SED lock. He only locked Rom.
PostPosted: October 2nd, 2018, 14:40
I didn't read my forum yet but ...
- Only PATA (IDE) old drives would store "S" on track 2. Modern drives do store "S" on other tracks.
- To bypass locked drive you can use command to regen "S", you can use same method as ZU to force password change, you can gain access to "S" and copy it out and replace it with "S" from unlocked drive, etc .... but this is to bypass ATA lock only.
- You need "S" otherwise the drive will show as ATA locked.
- If you do a factory format of all tracks for example with SeDiv "S" will be cleared like G-List, S.M.A.R.T., etc as all tracks will be gone (on platter). Now if you power off/on drive will be ATA locked. You have to re-create "S" using for example same VSC to clear password as that will make the drive produce the initial "S" and write it on track.
- On ALL Toshiba drives that i did saw so far if you don't have a "S" module the drive wll be locked. If you "damage" "S" the drive will be locked as well. Many times ATA password lock will apear on Toshiba even if client didn't set the password ... guess what .... maybe SA is damaged, heads are gone, pre-amp are gone etc .... if a correct "S" with correct content can't be read the drive will report and act as ATA locked.
Regards.
PostPosted: October 2nd, 2018, 19:09
Toshiba drives don't clear "S" module , SMART module, etc.....They replace them with template modules that are stored on the same tracks....Format tracks will erase the template modules as well...
PostPosted: October 3rd, 2018, 15:17
WRONG ....
:lol: :lol: :lol:
Try this :
1 - Use SeDiv or whatever tool and do a full format of the track.
2 - Check drive. It will be locked, slow, etc ....
3 - Use SeDiv or even directly issue the command to regen "S" module. Drive will be unlocked but still slow to detect as you don't have G-List, S.M.A.R.T., etc ...
4 - Use the command to regen G-List (clear), re-gen s.m.a.r.t. ,etc ....
5 - Drive will go full speed and will be ok.
6 - Now use your head and think ... IF Format tracks were to erase the template modules as well how would the command to regen the security work ? Just test it out and you will see ! Truth is when you do format tracks you can regen stuff and drive will be back to normal so regening with VSC doesn't require data on tracks (templates) to be there as you did already erase them with format tracks and you are still able to regen track modules by VSC !!!
Users browsing this forum: No registered users and 29 guests
