 Post subject: Problem with SEAGATE ST2000DM001
PostPosted: April 28th, 2017, 17:35
I have a problem with my 2TB disk of SEAGATE.
The disc is no longer seen by the bios. The engine runs smoothly, no click of the heads
And especially by connecting it with the serial port of the following messages:
Boot 0x40M
Spin Up
TCC-0016[0x000065B4][0x00006A20][0x00006E8C]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
TCC-0016
(P) SATA Reset
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MCMainPOR: EXCEPTION: MCMT PRI copy corrupt
MCMainPOR: MCMT SEC copy valid
Reconstruction: MCMT Reconstruction Start
Max number of MC segments 0A61
Nonvolatile MCMT sequence number 000031CB
[RSRS] 047E
ProcessRWError -Read- at LBA 000000000003A1E4 Sense Code=40000087
ProcessRWError -Read- at LBA 000000000003A1E6 Sense Code=40000087
ProcessRWError -Read- at LBA 000000000003A31F Sense Code=40000087
ProcessRWError -Read- at LBA 000000000003A458 Sense Code=40000087
[SW] 002F
[SW] 0030
[SW] 0031
ReadFooters (Forward): Segment 0481 StartLBA 00000000001D2278 Starting Footer L
BA 00000000001D2308
SeqNum 000031CF TotalUserBlocks 0008
ProcessRWError -Read- at LBA 000000000003A461 Sense Code=40000087
Valid Footer Obtained: ID/Seq D0D0CAFE 000031CF D0D0CAFE 000031CF
[SW] 0032
Reconstruction: Completed 1: Reconstruction occurred
[MCMTWS]
Rst 0x40M
Spin Up
TCC-0016
LED:00000047 FAddr:FFFFFFFE
The disk is a SEAGATE 2TB
Model: ST2000DM001
The firmware is: CC4C
The card has the following number: 100664987 rev A
Is there anyone who can help me to recover the functionality of this disk?
Thank you
 Post subject: Re: Problem with SEAGATE ST2000DM001
PostPosted: April 28th, 2017, 17:44
I would try to replace first copy of system file 346 with known good copy or copy from another drive.
Then i would reset/recover media cache and finaly i would disable it with congen.
PostPosted: April 28th, 2017, 18:43
Sorry but how can i do this you tell me. I'm not that practical. You tell me step by step how can I make this copy?
Thank you
PostPosted: April 29th, 2017, 3:05
Thank you
which tools do you have?
PostPosted: April 29th, 2017, 4:21
Thank you
I think, you are a usual user and you do not have experience and equipment to solve this problem. According to your problem, better to ask professional person/company in your region/country for assist untill your drive get in worse condition than currently.
PostPosted: April 29th, 2017, 13:19
Exactly, I'm a not so experienced user, but I want to try to run this disk. I use a serial to connect to the disk and how to use hyperterminal software. If I have to do some welding I have no problems or if I have to download a particular software.
If you can give me directions on how to do it.
Thank you
PostPosted: February 5th, 2018, 17:21
Hello. I have problems with this HDD. The terminal give mi this response. If somebody can help me. Thank you
Boot 0x40M
Spin Up
RECOV Servo Op=0100 Resp=0005
TCC-001D[0x000065B4][0x00006A20][0x00006E8C]
Trans.
Rst 0x40M
Spin Up
TCC-001D
(P) SATA Reset
(P) SATA Reset
SIM Error 3005 LBA 00000000000977A6 FD FC36C093
RW Error 00000080
MCMainPOR: EXCEPTION: SIM aborted prior to MCMT read
MCMainPOR: EXCEPTION: POR Failed General
MCMainPOR: Feature Disabled...
No HOST FIS-ReadyStatusFlags 0002A1A5
ASCII Diag mode
F3 T>
PostPosted: February 6th, 2018, 1:37
check this
http://blog.acelaboratory.com/pc-3000-h ... error.html
PostPosted: February 6th, 2018, 5:06
first of all check the NR-Glist.
F3 T>V40
PostPosted: February 10th, 2018, 14:51
Thanks you all for help me.
Now it gives me this start diagnosis.
Boot 0x40M
Spin Up
Trans.
Rst 0x40M
Spin Up
TCC-001D
(P) SATA Reset
MCMainPOR: Start:
Nonvolatile MCMT sequence number 000001E0
[RSRS] 014B
Reconstruction: Completed 0: HeadPtr was unwritten
[MCMTWS]
MCMainPOR: MCTStateFlags 0000002A MCStateFlags 00000041
MCMainPOR: Feature Enabled...
Total AC8, Head AA0, Tail 28 Retry 0 Status 0
Total AC8, Head AA0, Tail 28 Retry 1 Status 0
Total AC8, Head AA0, Tail 28 Retry 2 Status 0
InitiateMarkPendingReallocateRequest for disc_lba: 000000000008990F!
InitiateMarkPendingReallocateRequest for disc_lba: 0000000000089910!
InitiateMarkPendingReallocateRequest for disc_lba: 0000000000089911!
PowerState = IDLE1
PowerState = IDLE2
APM disabled by SPort
ASCII Diag mode
Thank you.
PostPosted: February 10th, 2018, 14:53
F3 T>V40
This is the log of V40
F3 T>V40
Primary DST List 29 entries returned
Total entries available: 29
PBA Len Flags Phy Cyl Hd PhySctr SFI
Nonresident GList 29 entries returned
7BDBC 2 20 169 1 EE F42F2
7BF12 2 20 16A 1 D6 F3B08
7C069 2 20 16B 1 BF F3F20
7C1C0 2 20 16C 1 A8 F434E
7C316 2 20 16D 1 90 F3B64
7C46D 2 20 16E 1 79 F3F7C
7C5C4 2 20 16F 1 62 F4394
7C71A 2 20 170 1 4A F3BAA
7C871 2 20 171 1 33 F3FC2
7C9C8 1 20 172 1 1C F43DA
7CB1E 2 20 173 1 4 F3BF0
7CF39 2 20 175 1 143 F37F4
898F4 1 20 12A 0 0 12EC92
A260B 24 20 176 1 AF F3DAD
A2761 29 20 177 1 97 F3582
A28B8 24 20 178 1 80 F39DA
A2A0F 35 20 179 1 69 F3DF2
A2B66 2 20 17A 1 52 F420A
A2CBC 2 20 17B 1 3A F3A20
A2CC5 1 20 17B 1 43 FA872
A40E9 1 20 189 1 63 F5016
A4A5D C 20 18F 1 143 F37F4
A53D3 8 20 196 1 B7 105747
A6BEB 2 20 1A7 1 81 F3AA6
A6D42 2 20 1A8 1 6A F3EBE
A81C9 2 20 1B6 1 ED 218A2
A8571 19 20 1B9 1 4B F3C76
A9AFC 1 20 1C8 1 64 FAC92
A9B07 1 20 1C8 1 6F 103368
A9B0A 1 20 1C8 1 72 10586E
A9DA3 2 20 1CA 1 2F F5EF4
A9DA6 2 20 1CA 1 32 F83BA
AA05C 1 20 1CC 1 C FEE3A
AA060 1 20 1CC 1 10 101F82
AA1C4 2 20 1CD 1 6 10C334
AA31A 4 20 1CD 1 15C F9C9A
AA329 3 20 1CD 1 16B 1054B9
ADCCF 5 20 1F6 1 73 F3AB4
308FED 2 20 74B 3 115 E97D
308FF6 1 20 74B 3 11E 157C9
1D27D812 1 20 503EA 0 8F 5CB78
PostPosted: February 10th, 2018, 17:06
Stop playing with the drive and send it to a proper data recovery firm if you need the data ?
Because if you keep on messing with the drive without backing up sysfiles and modules first there is a BIG risk of damaging the drive for good making the data un-recoverable.
If the data is not needed then buy a new HDD and don't buy Seagate.
PostPosted: February 11th, 2018, 4:19
+1
WD Trusted Partners
PostPosted: February 11th, 2018, 20:24
Thank you. I don`t need data from this hdd, but if iss there any way to fix it and if you can help me.
Thank you all.
PostPosted: February 13th, 2018, 18:13
If you don't need the data then buy another drive and don't buy Seagate ever again. There is no way to "fix" the drive for re-use. It already failed so it would be a crazy idea to use that drive again. Even if the drive were to be "new" it would be already a crazy idea to use it (as it's junk) even more now that it failed.
Users browsing this forum: Google [Bot] and 21 guests
