 Post subject: Thorough disk scanning
PostPosted: February 19th, 2018, 21:22
Mhdd's scanning only performs READ ONLY scanning. But there might still be a problem with writing data into sectors. Is there a piece of software that performs more thorough test i.e. READ-WRITE test (destructive for data I understand)?
thx
 Post subject: Re: Thorough disk scanning
PostPosted: February 20th, 2018, 2:08
Here is one:
https://en.wikipedia.org/wiki/Badblocks
PostPosted: February 20th, 2018, 10:16
MHDD should be able to write to the drive as well. Insteal of "scan" use "erase" ?
You can use Victoria for windows as well.
You can try the standad ATA command for security erase with the known limitations mentioned here - http://www.hddoracle.com/viewtopic.php?f=56&t=1412
And you might like to read here as well - http://www.hddoracle.com/viewtopic.php?f=117&t=1393
Regards.
PostPosted: February 20th, 2018, 21:00
Hard Disk Sentinel can perform :
– read scan
– write scan
– write + read
– read + write + read (that one *should* not cause data loss, it re-writes the sectors just as they have been read, but it's highly recommanded to backup anything remotely important beforehand ; obviously it's a very long test, and there shouldn't be any power failure until it's over, better use a UPS)
– and “disk repair” (it's supposed to do a read scan, and only attempt to write on weak sectors, so as to restore them if possible, or reallocate them if not)
Users browsing this forum: Bing [Bot], Google [Bot], Majestic-12 [Bot] and 22 guests
