 Post subject: WD5000LPVX-75V0TT0
PostPosted: March 8th, 2018, 12:34
Hello
This Hubble_LT takes a while to become ready then shows only SN.
No SA/user access
Any thoughts?
Thanks in advance
 Post subject: Re: WD5000LPVX-75V0TT0
PostPosted: March 8th, 2018, 12:37
Online
Is this before or after head swap? If after, there is a chance the donor heads aren't compatible enough.
Hard Drive and RAID Data Recovery Specialist in Massachusetts
PostPosted: March 8th, 2018, 12:56
I have just took it from the client. Didn't do anything yet but diagnosis.
PostPosted: March 8th, 2018, 12:59
Online
Have loader to test? Typically it is firmware and heads issues, where one surface is great and the other makes it pull your hairs out.
PostPosted: March 8th, 2018, 13:03
Tried Loader 0005001G, no SA access. ( with and w/o SA blocked )
PostPosted: March 8th, 2018, 13:04
Online
Sounds like head(s) issue. More testing needed.
PostPosted: March 8th, 2018, 13:05
I will try with a donor heads and post results.
Thanks for your inputs.
PostPosted: March 8th, 2018, 14:00
@ labtech,
Thank you very much. Case solved ( heads )
Drive cloning now with ~100MB/s. :)
PostPosted: March 8th, 2018, 15:09
Online
nice, glad it worked out
PostPosted: March 8th, 2018, 15:11
:good:
Users browsing this forum: Bing [Bot] and 39 guests
cron
