 Post subject: Looking for ROM/LDR for WD10EACS - 00ZJB0
PostPosted: March 9th, 2018, 4:23
I am looking for ROM/LDR combination that I can try to attempt to gain access to the SA on this case I have. Any help is appreciated!
Drive model is - WD10EACS - 00ZJB0
 Post subject: Re: Looking for ROM/LDR for WD10EACS - 00ZJB0
PostPosted: March 9th, 2018, 4:26
What ROM version are you looking for?
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: March 9th, 2018, 5:40
The original board was fried from a power surge, I am definitely new in this field but I do have someone who is very reputable here helping me and he instructed me to find a ROM/LDR combination that allows me SA access. I am assuming that we are not able to identify the version and will try whatever is available, if I am wrong in saying this than correct me and I can go and get you the version.
Thanks!
PostPosted: March 9th, 2018, 6:24
That drive has Pcb 701474-xxx...right?
There is no external ROM on that one, just embedded in CPU.
So either repair Pcb, or hotswap it to get access to modules that holds ROM backup.
http://www.rescue-it.se
PostPosted: March 9th, 2018, 19:17
Thanks!
If the data is important send the drive to a reputable data recovery firm.
If your friend there is so "reputable" as you say he wouldn't be telling YOU to find the ROM/LOADER YOURSELF and instead he would know how to gain access to SA HIMSELF.
Just get a compatible PCB to start with and use your firmware tools to check if you can read SA.
What tools are your "friend" using ?
PostPosted: March 9th, 2018, 20:08
Spildit wrote:
Thanks!
Agree
PostPosted: March 9th, 2018, 20:28
What do you mean by "fried"? Is the motor controller chip burnt? If not, did you check the TVS diodes?
Catastrophic failures in Western Digital PCBs:
http://www.hddoracle.com/viewtopic.php?f=100&t=2169
TVS diode FAQ:
Users browsing this forum: Google Adsense [Bot] and 31 guests
cron
