 Post subject: Smart Fail Toshiba MK6465GSX
PostPosted: March 10th, 2018, 4:56
Hello My Friends
I have a toshiba hdd model MK6465GSX and problem is smart fail And Speed is very low !
i need fix this HDD and i connect TX RX Connector and open hyper terminal and config bit per second 9600 and trun on hard disk but nothing to happened and not show anything on hyper terminal console !
my usb to ttl convertor chipset is cp2102 .
Is there a problem with the converter?
i,m check 3 model toshiba hdd with this convertor but not working , and i chek with seagate hdd and working convertor !
how can i access toshiba hdd terminal ?
Regard , thanks
Sorry English is not my first language .
 Post subject: Re: Smart Fail Toshiba MK6465GSX
PostPosted: March 10th, 2018, 7:13
My poor advice: trash this drive and buy a new one.
Good luck
PostPosted: March 10th, 2018, 11:13
If you are sure of that speed of 9600, try pressing Enter after turning on the disk
PostPosted: March 10th, 2018, 19:12
Hi there !!!
If S.M.A.R.T. "faild" please do post a screen capture of S.M.A.R.T. attributes retrieved with something like MHDD or Victoria for windows. What did fail exactly ?
If the drive is "slow" and/or have huge amount of bad sectors most likely one head (or more) is gone - this happens allot with Toshiba GSX. You will not be able to fix broken head with terminal. Same as if you have damaged "zones".
If drive is slow then i assume you can detect the drive by ATA.
What do you plan to do on terminal ???
Connect the drive and press enter.
If you see > you are good to go, if not swap tr/rx. Make sure it's connected correctly (correct pins). But then what ? ....
Assuming youi get a > prompt what do you intend to do ?
Unless you have tools or Vendor Specific Commands to use with ATA terminal (or even TTL as long as you know the commands) i don't see how you will "fix" the drive.
If the data is important consult with a data recovery firm, if not buy a new drive.
I do have a HUGE amount of GSX drives with damaged heads .... One can use a procedure like this but ALL DATA WILL BE GONE !!!
http://www.hddoracle.com/viewtopic.php?f=119&t=1900
http://www.hddoracle.com/viewtopic.php?f=119&t=1897
Regards.
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot] and 38 guests
