Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: WD Scorpio Blue not reading sectors
PostPosted: April 25th, 2018, 19:45
It's a little bit off topic but it shows how to check if a drive is locked by ATA password by reading the ID block retrieved with ec command.
I would just like to point out that the results of the identify device command from CrystalDiskInfo do not appear to be word flipped (little endian). They are strait up which is different then many other raw output formats. That is one reason I asked to make sure the ASCII View was checked, so that it could be seen that the results were not flipped. It can make a big difference in which bit you are looking at.
http://www.sdcomputingservice.com
Home of HDDSuperClone and HDDSuperTool
PostPosted: April 25th, 2018, 20:14
Ok, let's try this :
This time with a WD Marvell ROYL drive :
:D :D :D
PostPosted: April 25th, 2018, 20:19
And in normal format :
PostPosted: April 25th, 2018, 20:25
I would say dump the drive ID with command EC and don't swap bytes just grab the standard output as in ATA standard then locate offset 100h on the dump and check the 2nd byte. If 00 then drive is unlocked and if 01 then drive is locked.
But i would bet that the drive is unlocked and the problem is elsewhere.
PostPosted: April 25th, 2018, 21:22
Some time ago I requested that the author display the data in a way that matches the format in the ATA standards documents. That's why the words are byte-swapped and the rows and columns are numbered in decimal.
PostPosted: April 26th, 2018, 14:40
Let's make things easier ...
You have a BAD WD drive that you need to test. Forget about that CrystalDiskInfo and EC command.
Get Victoria For Windows - http://www.hddoracle.com/viewtopic.php?f=36&t=36 - You will need this to attempt to scan your drive. If the drive is locked you will see something like this :
Get WDMarvel DEMO - http://www.hddoracle.com/viewtopic.php?f=146&t=2435 - You will need this to attempt to get your drive Modules and ROM copy. If the drive is locked you will see something like this :
No need to make things harder and you will need those tools anyway ...
PostPosted: April 26th, 2018, 14:42
And just for reference ...
PostPosted: April 26th, 2018, 17:53
The OP stated they were getting another computer around for all the testing. All I did was give a very simple way to provide us some data until then, and something that would only take a few minutes. Somehow that got blown up into a technical explanation, and then seemingly now deemed complicated.
:roll:
PostPosted: April 26th, 2018, 18:00
:roll:
Sorry ....
Let's wait for the OP to reply then !
:D :D :D
PostPosted: April 26th, 2018, 18:08
I have put up a PC based on Inter Atom (WAFFER), small factor, and I connected Seagate disk with Windows XP, and faulty WD on second SATA interface.
Windows starts loading and throws bluescreen.
So I cannot run any diagnostic software on it.
I have to try on different mainboard and maybe different Windows.
The WD is however detected on other machine with Windows 7 but on USB interface, and tools don't see it.
PostPosted: April 26th, 2018, 18:11
But does windows load when the bad wd isn´t connected ?
PostPosted: April 26th, 2018, 18:12
Sure, it works ok without the bad disk
PostPosted: April 26th, 2018, 18:17
Get Victoria and WDMarvel demo installed on the computer.
Both can be made to re-scan for hard disks after they are loaded, so wait then for someone to instruct you about that.
PostPosted: April 26th, 2018, 18:20
maximus wrote:
it is valuable but not worth $800, and I got such price quote from professional recovery service.
Was the drive sent to this company for inspection and quote, or is this just a general quote price?
This question seems to be unanswered...
PostPosted: April 26th, 2018, 18:23
I described them symptoms, and they gave me the price quote, no inspection.
PostPosted: April 26th, 2018, 18:32
Create a bootable disk of MHDD from
http://files.hddguru.com/download/Software/ file mhdd32ver4.6iso.zip then see if it detects your disk.
PostPosted: April 26th, 2018, 18:37
Ok, instead of faulty WD plug another good drive on that same port and run your WINDOWS ! Make sure that you have set on BIOS IDE/Compatible mode on that same SATA port. Now with windows already running and Victoria / WDMarvel installed just remove the power/sata cable from the 2nd drive and plug the damaged drive there ! Run WDMarvel and scan the same SATA port where you did have the other working drive.
PostPosted: April 26th, 2018, 18:38
You can do the same using Victoria and check PIO mode, detect the port where you have the bad drive plugged and see if you can ID the drive and scan it...
PostPosted: April 26th, 2018, 21:26
- electronics responds, at least disk geometry returns correct values
- Windows sees it as uninitialized
So did windows report the proper drive size in disk management? Your original post indicated that the drive had the proper geometry, which I took to mean that it showed the proper drive size.
PostPosted: April 27th, 2018, 18:51
Spildit wrote:
I would vote for head damage or modules damage but if the drive picks up ok with correct geometry then i would vote for translator not loading because of damaged head.
There is one other possibility, IF the drive does identify correctly at least once when powered on. When the drive reads a bad spot, it could go into a device fault condition. This can happen when the OS tries to read data such as the MBR and partition data (you would be surprised the crazy sectors the OS can want to read when it detects a drive). Once in device fault, all reads will fail instantly, as likely will all commands, even the identify device command. The drive will not respond properly again until it is power cycled. This makes it possible for a drive to show up in the OS with the correct size, but then appear to be dead because it went into fault.
This condition can potentially be overcome when using a hardware imager that can perform resets based on a timeout. The resets can prevent going into fault. So if this ends up being the condition, it may still be possible to read data from the drive. I can do it with software :)
Users browsing this forum: Google [Bot] and 50 guests
