when connected, the disc rotates for a few seconds then stops, then rotates again and so on.
I have had similar cases before that were solved with a change of pcb, but this particular case leaves me with no options.......
patient disc + pcb donor + patient rom ----> same result (spin up/down constantly) ------> discard pcb problems
patient disc +pcb donor + rom donor ---> same result ----> discard corrupt rom problems
Isolated head contacts ---> same result ---> would rule out preamplifier or head problems
Am I missing something??
motor damage???.... but it would be the first case I see in this series and even less when it turns (not blocked).
Has anyone ever had this happen to you? And most importantly, what was the solution??
