 Post subject: WD Green HDD not getting detected in BIOS and Windows
PostPosted: May 22nd, 2018, 8:07
My 1TB WD Green HDD is not getting detected in BIOS. So, i used a docking station in another PC to investigate what went wrong. I used a number of partition utilities to investigate. I am sharing the results. Please guide me.
 Post subject: Re: WD Green HDD not getting detected in BIOS and Windows
PostPosted: May 22nd, 2018, 8:31
In my opinion you need to consult a pro, before it's too late.
In the last screenshot, the drive responds with a CRC error, which can be caused by failing/weak heads (amongst others).
If the data is valueable, I wouldn't risk hammering it with various software solutions.
WD Trusted Partners
PostPosted: May 22nd, 2018, 12:16
Well,
i see you are from india .I have some of my trained students near your place " balasore " .If you are interested i can send you their address ,You can pm me your No .
PostPosted: May 22nd, 2018, 15:55
If you are going to risk to loose all the data for good at least :
- Connect the drive by SATA and NEVER USB.
- Check S.M.A.R.T. for re-located and pending sectors. If any consider that the drive might have a slow issue as well.
- Patch the firmware if needed to disable re-loaction.
- clone the drive to another one using ddrescue or HDDSuperClone.
- If needed extract the data FROM THE CLONE using something like R-Studio.
Of course if data is of any importance to you do consult with a specialized data recovery firm !
Good luck !
PostPosted: May 23rd, 2018, 2:12
Amarbir[CDR-Labs] wrote:
Well,
My mobile number is : 9439300565. I cannot PM you at the moment as i am not yet provided with the facility.
Users browsing this forum: Google [Bot], MSN [Bot] and 26 guests
