 Post subject: Toshiba P-list recovery
PostPosted: May 8th, 2018, 14:31
Again a Toshiba with a new issue. It surely indicates Toshiba is been replaced by Seagate.here in India.
I have got a Toshiba DT01ACA100 1Tb Desktop hard disk. Drives Heads were weak ,so we replaced by 100% compatible Healthy Heads , We have been able to read few modules as well. However crucial P-List is Zero filled ( is empty).
Earlier client has given disk to other companies . We have confirmed pcb is native . Is there any way to know how p-list has suddenly become zero ?
Has someone gone through similar situation before ? Without P-list Recovery will not be possible.
If Donor Heads put back in Donor they work fine so there is no damage to platters.
How to deal with this situation? Can someone pls. help.
Thanks .
 Post subject: Re: Toshiba P-list recovery
PostPosted: May 8th, 2018, 14:37
DT01ACA100 - Hitachi ARM and NOT TOSHIBA ...
PostPosted: May 8th, 2018, 14:42
What modules were you able to read and with WHAT utility ?
Seagate is JUNK (F3 ARCH drives). Those HGST drives are good.
What is the problem with the drive ? Can't you read LBAs at all ? Does the drive ID ?
On Toshiba native it should be possible to scan LBAs even if P-List is gone but you will have data shifts if you clone/image unless you can reach bad sector and add it manualy to P-List to rebuild it but if the bad sector is "recent" even if it were added to G-List you will get shifts as well. If you do a good job you can still recover the data. This assuming you have a cleared DD. This doesn't apply to HGST.
On HGST you shouldn't be able to read sectors past the first entrie on P-List. This is the same as with partial access problem on F3 Arch as CRC/Header of sectors will not match translator. Still possible to "fix" but expect to spend a huge amount of $$$$
PostPosted: May 8th, 2018, 14:44
:idea:
Earlier client has given disk to other companies !
Does the "other companies" have tools to clear the P-List in case the client declines to pay ?
:lol: :lol: :lol:
PostPosted: May 8th, 2018, 14:48
Thanks .
If this is really HITACHI and if all copies of P-List are gone and if the drive doesn't have any other problem (just a P-List erased/deleted by other DR FIRM) i think that i could rebuild it but i would have to charge some considerable amount of $$$ and i would need to have the drive with me as i'm not using PC-3000.
The "plan" would involve attempt to read copies of the P-List and if it fails attempt to read by LBA to the first problematic sector and add to P-List manualy and re-scan and so on up untill drive provides 100% LBA access. It might be very time consuming if there are a huge amount of defects on P-List.
PostPosted: May 8th, 2018, 21:48
Hi Spildit
Thanks :good: You are single handedly managing battle.
I will post all drive details which might throw light on the case.
Thank you so much.
PostPosted: May 9th, 2018, 14:04
posidon wrote:
Hi Spildit
Thank you so much.
Please do post more info as well like what PC3K utilities you did use, etc ...
Regards.
PostPosted: May 10th, 2018, 10:25
Hi Spildit
I have sent you nvram and rom in PM.
PostPosted: May 15th, 2018, 2:04
Update on this case ---- Tragic End
It seems this disk is one of the Non-Recoverable type. I think drives SA is having bad sectors , actually P-list might not be zero filled but due to defects it might appear empty. As spildit has outlined P-list can be rebuild by manually adding defects ,but is it too much time consuming and if SA is bad then P-list cant be written .I have tried to write few bytes in SA modules but it cant be written.
A tragic and sad end to this case shattering customers critical data and hopes . A failure is hard to disgest. :(
PostPosted: May 15th, 2018, 15:12
I would still try to contact member drHDD and check if he can help you out :
memberlist.php?mode=viewprofile&u=31114
Regards and good luck.
Users browsing this forum: cpm0088, Google [Bot], hhhpppsss, parmindo and 26 guests
