 Post subject: ST2000DM001 suddenly stopped working
PostPosted: June 1st, 2018, 10:50
This is (was) dual boot Win7/Ubuntu system. No indication of trouble (although I wasn't checking for it) until one day it wouldn't boot. Wasn't identified by UEFI. Information isn't critical but would be nice to get so want to try DIY. Virtually all the useful files are in the Win7 NTFS partition. I have read that Linux may be able to read the data so could try a linux live CD or plug it into the same PC that has a new hard drive and Ubuntu. But since the UEFI can't identify is this worth trying? I have done a bit of reading on this but I don't have any experience with HDD recovery.
 Post subject: Re: ST2000DM001 suddenly stopped working
PostPosted: June 1st, 2018, 12:30
What do you consider cost "not very high"? I asked one place and was quoted about $800 and that was just the starting point. Still wanted me to buy a drive to put the image on and the disclaimer it might go higher. How do you find a reputable but reasonable cost place?
In any case I want to try to do this myself as it's not critical I recover the files. I have TTL adapters from other projects that I can use. What are the logic levels? 3.3V? I can measure to be sure.
Direct SATA connection.
It does spin. I will do some more checking, download the programs and get more information.
PostPosted: June 1st, 2018, 23:24
Any tips on connectors for the TTL interface? The spacing of the pins is odd and measures about 0.070" pitch. The sockets I have are too big to fit. I could get sockets from a smaller pitch and use them.
PostPosted: June 2nd, 2018, 10:56
Downloaded iso image with MHDD, burned CD, and ran this on PC with new drives to check it out on a good drive before on the bad drive. I get option to select drives:
1. Primary controller
3. Secondary controller
5. PC-3000
All the spaces below the selections are blank - not sure if this should show drives. When I try to select I just get "drive not ready" for any of them. The drives are working fine for normal use though.
Drives are SATA. Motherboard is ASRock Z87 Extreme4. I have looked at MHDD documentation several places and can't see what the issue is.
On the connector I remeasured more accurately and the pitch is 2 mm. This is a very standard pitch, just smaller than I have on hand (Mostly 0.1" stuff) so I will make up something.
PostPosted: June 2nd, 2018, 11:41
I just wrote up a post but don't see it. Is this because of moderation of new member posts? It happened on one of my previous ones but I could see a notice about moderation that I don't see now.
I downloaded the iso with mhdd, burned a disk, and booted it. This was on my PC with new drives to see how it detected a good drive before using it on the bad drive. I got a selection menu:
5. PC-3000 board
There were also some spaces between the selections that were blank but appeared to be for disk IDs or something like that. When I tried to select a drive I got "drive not ready" for any selections I tried. I have two SATA drives in the machine that work fine in normal operation.
I looked at several sites documentation but am not able to figure out what I should be doing or what is going wrong.
For the connector for TTL I remeasured more accurately and the pitch is 2 mm, which is a standard pitch. Most of my pin connectors are 0.1 inch so I will have to come up with something. It looks like Samtec series ESQT would work well or I may cut down something I have.
PostPosted: June 2nd, 2018, 12:39
Set to IDE. MHDD detected my drives fine. Attached the bad drive. It didn't find it. UEFI didn't see it either. The drive made about 5 repeated noises that sounded like head seeking on power up.
PostPosted: June 2nd, 2018, 22:07
I think it continues to spin but I will check again. No scratching or clicking noises. The only unusual sound is the soft buzz of the head seeking a few times. Will hook up a ttl cable. Do I need to enter any commands for initial look or just capture what it sends out?
PostPosted: June 6th, 2018, 9:06
Got the interface working with the help of a scope. 1.8V signals, 38,400 baud. Output pin from drive is next to ground pin. Here is the output:
Boot 0x40M
Spin Up
FAIL  Servo Op=0100 Resp=0007
ResponseFrame EE80 0074 06CC 3D00 0008 0000 0000 0000 0C54 0000 0000 0000 0000 0000 0000 0000 ED8C 1C83 FFFF 2000 2316 0000 0000 47F7 0000 47F7 0000 2247 0000 0020 0018 0007 0010
FAIL  Servo Op=0100 Resp=0003
ResponseFrame E6C0 0073 06CC 3D00 0008 0000 0000 0000 0C54 0000 0000 0000 0000 0000 0000 0000 ED8C 1C83 FFFF 2000 2316 0000 0000 47F7 0000 47F7 0000 007F 0000 0020 0018 0004 0000
ResponseFrame E6C0 0073 06CC 3D40 0008 0000 0000 0000 0C45 0000 0000 0000 0000 0000 0000 0000 ED8C 1C83 FFFF 2000 2316 0000 0000 47F7 0000 47F7 0000 007F 0000 0020 0018 0004 0000
ResponseFrame E5C0 0073 06CC 3D40 0008 0000 0000 0000 0C45 0000 0000 0000 0000 0000 0000 0000 ED8C 1C83 FFFF 2000 2316 0000 0000 47F7 0000 47F7 0000 007F 0000 0020 0018 0004 0000
ResponseFrame E540 0073 06CC 3CC0 0008 0000 0000 0000 0C62 0000 0000 0000 0000 0000 0000 0000 ED8C 1C83 FFFF 2000 2316 0000 0000 47F7 0000 47F7 0000 007F 0000 0020 0018 0004 0000
ResponseFrame E4C0 0073 06CC 3CC0 0008 0000 0000 0000 0C62 0000 0000 0000 0000 0000 0000 0000 ED8C 1C83 FFFF 2000 2316 0000 0000 47F7 0000 47F7 0000 007F 0000 0020 0018 0004 0000
ResponseFrame E480 0073 06CC 3D00 0008 0000 0000 0000 0C54 0000 0000 0000 0000 0000 0000 0000 ED8C 1C83 FFFF 2000 2316 0000 0000 47F7 0000 47F7 0000 007F 0000 0020 0018 0004 0000
ResponseFrame E440 0073 06CC 3D00 0008 0000 0000 0000 0C54 0000 0000 0000 0000 0000 0000 0000 ED8C 1C83 FFFF 2000 2316 0000 0000 47F7 0000 47F7 0000 007F 0000 0020 0018 0004 0000
ResponseFrame E400 0073 06CC 3CC0 0008 0000 0000 0000 0C62 0000 0000 0000 0000 0000 0000 0000 ED8C 1C83 FFFF 2000 2316 0000 0000 47F7 0000 47F7 0000 007F 0000 0020 0018 0004 0000
ResponseFrame E400 0073 06CC 3C80 0008 0000 0000 0000 0C71 0000 0000 0000 0000 0000 0000 0000 ED8C 1C83 FFFF 2000 2316 0000 0000 47F7 0000 47F7 0000 007F 0000 0020 0018 0004 0000
ResponseFrame E380 0073 06CC 3C40 0008 0000 0000 0000 0C7F 0000 0000 0000 0000 0000 0000 0000 ED8C 1C83 FFFF 2000 2316 0000 0000 47F7 0000 47F7 0000 007F 0000 0020 0018 0004 0000
Users browsing this forum: Google [Bot] and 16 guests
