Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2
 Post subject: Re: Solving Seagate Rosewood having Translator issue.
PostPosted: June 30th, 2018, 0:44
reco wrote:
Well,
Seagate Rosewood drives are with firmware lock, the very first thing is to unlock; after that, we can not regenerate translator immediately, cuz that will lead to user sector access interruption and we can not restore the disk to the status before regenerating translator (but with backup of sys file, such attempt will have no threat to client data, we can still restore the disk to its original status).
The right procedures to fix Rosewood are:
1. Unlocking;
2. Backup firmwares especially sys file of 28 and 35;
3. Recalculate translator, and fix user sector access interruption (Restore the disk to its original status with the ablility of writing back sys file).
I kindly disagree.
WD Trusted Partners
PostPosted: June 30th, 2018, 2:30
ddrecovery wrote:
I have just attended the Ace Labs conference in Las Vegas. Ace have created a way to resolve media cache issues with Rosewoods. As stated earlier, the media cache on modern drives can be extremely large (up to 90GB). The media cache does contain a lot of recently saved data. Ace did not have a launch data for the fix, but I can assure you it does work and will be available soon.
Also included with be a way to physically recover the entire media cache for examination from a forensic standpoint. So even if the drive has been wiped, the media cache will contain a lot of recent files.
Ehh, on modern drives, drives with larger media cache size applies to SSHD only. Larger media cache can improve drives' performance, but it makes no sense to make media cache up to 90GB; Cuz media cache of SSHD is stored in its SSD chip, the capacity of these chips can be found directly from manufactures' specifications; If the capacity of the chip can be up to 90GB, definitely it contradicts with commercial principles.
From above view, Ace said media cache can up to 90GB, I will take a sceptical eye on it.
PostPosted: June 30th, 2018, 2:35
northwind wrote:
reco wrote:
Well,
1. Unlocking;
I kindly disagree.
What is your opinion? It would be glad to all of us if you can share your thoughts to us :)
PostPosted: June 30th, 2018, 9:22
reco wrote:
(...)From above view, Ace said media cache can up to 90GB, I will take a sceptical eye on it.
If you "blindly" format the translator the data on the media cache will be gone, so if it's indeed 90GB will will loose the last 90GB of data that was used and present on MC ...
Why do you think that the media cache does apply only to SSHD drives ? This is NOT TRUE. Standard modern Seagate drives even if they don't have NAND chips and are not Hybrid drives they do have/use MC....
PostPosted: June 30th, 2018, 12:10
northwind wrote:
reco wrote:
Well,
1. Unlocking;
I kindly disagree.
+1 ,
Thanks Correct Dimitry Sir
PostPosted: July 2nd, 2018, 7:26
reco wrote:
Well,
1. Unlocking;
All who trying recalculate translator on modern seagate drives are amatours. They dont know how things is going in sa.
Translator isn't a couplrit . And you can't backup everything in SA due of bad sectors in specific modules responsible for user data access.
Raid reconstruction solutions
Whatsapp: +971552737521
PostPosted: July 2nd, 2018, 9:55
Have too add defect in nrg.. Complex but solvable.
DF :)
www.datatracksystem.net
PostPosted: July 2nd, 2018, 9:59
DR-Kiev wrote:
reco wrote:
Well,
1. Unlocking;
Agreed With Dr.
DF :)
PostPosted: July 2nd, 2018, 23:06
DR-Kiev wrote:
reco wrote:
Well,
1. Unlocking;
The most important are sys file of 28 and 35, and if you can not backup modules due to bad sectors, you can also try to read via ABA method; if still not, please ask Jesus for help :)
PostPosted: July 4th, 2018, 23:11
So if I will give you rosewood with cleared SA and 28 and 35 from it - you will able to get access to all user files, right?
PostPosted: July 5th, 2018, 22:57
We are not near, if yes, I can try :D
Luckly, I have done some cases successfully, and yesterday, I fixed a customer case with sys 28 only;
Translator issue is complicated, there is no must success solution, but with backups, at least we restore to original status for future attempt.
PostPosted: October 22nd, 2018, 22:59
I find a viedo in Youtube as below:
https://www.youtube.com/watch?v=7EL5PWOm-do&feature=youtu.be
MRT Express & Ultra, Professional Data Recovery Tool
Email & Skype: sales@mrtlab.com
Whatsup: +8615827155998
PostPosted: October 23rd, 2018, 9:14
man you work so fast, you found it minutes after you uploaded....bravo!
HddSurgery - Professional Data Recovery Tools
PostPosted: October 23rd, 2018, 9:44
reco wrote:
Well,
1. Unlocking;
and what if the sysfile 28 is corrupt which is some time the case ?
As many respected members mentioned this, regenerating translator is not a good solution to work with these drive, there are definitely other ways to solve most of the problem without touching the translators.
Data Recovery Pakistan
PostPosted: October 23rd, 2018, 9:47
1 regenrate and have to add defect 8n defect list. Correct me i am wrong.
Vikas Seth
DF :)
PostPosted: November 16th, 2018, 23:49
you are good, man! :lol: :lol: :lol:
@mrtpro, Ivy? or Wang? you guys are so fun, why do not you guys said that is your work directly? what you afraid for? :lol: :lol: :lol:
PostPosted: November 17th, 2018, 0:53
MindMergepk wrote:
reco wrote:
Well,
1. Unlocking;
some case I encountered with good sys 28. What i suggested here before is in order to provided a manner to help Data recovery engineer to solved Rosewood hard drive translator issue temperately. The fact is my suggestions really works in some case.
There must be a way to solve this problem not by regenerating translator, either PC3K or MRT they had such solution at moment yet. It is nearly five months passed when ACE release 90G Media Cache theory in Vegas, I still take a sceptical eye on it.
PostPosted: November 17th, 2018, 4:50
Vikas Seth
your method might work, i never used it like this.
There is definitely other and better way to deal with 28 sysfile corruption.
Users browsing this forum: Bing [Bot], Exabot [Bot], Google [Bot] and 22 guests
